lightweight rims
I've an Excel spread sheet that has a ton of
weights for a ton of wheels...dont remember how/where I got it but I have it...what size rim R U looking for?
Or, send me an email, I will attach the Excel file & return to u...
Re: lightweight rims
Originally posted by csvencer
What rims are nice and light for there size? The centerline RPM's are light and I looked at the Konig Tantrums but they didn't have a weight listed. Every pound counts.
-svence
-svence
Re: BTW, Konig Tantrums are NOT light...these
Originally posted by Galo
are on my spread sheet and a couple of 18" sizes weigh as follows:
Konig Tantrum Cast 18x7.5 23.2
Konig Tantrum Cast 18x8 24.9
galo
galo
How much does the Mille Miglia evo 18x8 wiegh? They are heavy when i lifted it to mount it on the car...
Originally posted by bassfreak
i have the black pearl centerline rpm's on my 2k black max. they are amazing. but be prepared they took 5 weeks to come in. but this could have just been my luck.
-svence
-svence
BTW, my definition of lightweight 18's means less than 19 lbs. If you are willing to go 7.5" width then you'll have a plethora of light wheels to choose from that are reasonably priced.
Anyway, from my research, apart from the very expensive ones $400+ per wheel (SSR comps, Racing Harts, Volks, etc.) here are the only other lightweight (<19 lbs) 18 x 8 ones I found below $400 per wheel.
1) Enkei RPM2 $250+ per wheel 18.5 lbs
2) O.Z. superleggeras (what I have)$330+ per wheel 18.3 lbs
3) SSR GT1 $399+ per wheel 19 lbs
Re: Naerok..you're correct...the Mille Miglia Evos
are heavy mothers...direct from my spread sheet:
Mille Miglia Evo Cast 18x8 27
But, i'm really not going for speed, more of looks and better handling, so that is my trade-off.
So do you think the extra inch or half inch is worth the money, will the handling be noticeably different?
-svence
-svence
) rims put on with Kuhmo 711 225/45r 17 put on today from Discount Tires for about $1150 for everything.. and damn, these rims look nice and they are light. they are about 15lbs each. Very nice ride and everything, all he needs now is to lower his car and everything is set. If you want some light rims and that wont cost you a fortune, goto a Discount Tires store and they will most likely drop it down to about the same price my friend got his at. The rims are usually $200 each.
Originally posted by BlueC
Hey, my friend just had those 17x7 5zigen F01r-c (something like that
This is what I went with.
Kosei Penta RT 17x7.5, 16lbs in Pearl Black
http://www.faswheels.com/products/wheels/rt_penta.htm
Originally posted by DrVolkl
I like the look of that rim a lot...especially in the hyper black. Will that fit on a 2k2?? If so, SOLD
Re: I've an Excel spread sheet that has a ton of
Thanks!
what do you guys think about these im thinking about getting a set i have a 2002 black SE how do you think it would look?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2417714873
-svence
-svence
i found the centerline rpms for sale on ebay if anyone is interested...here is the link
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2418135378
Originally posted by woreyah
Food for thought:
Take 2 wheels that weigh the same. One is a 17 inch wheel the other 18. Because the 18 inch wheel has more mass it will still require more energy to rotate.
Food for thought:
Here is the kicker.
Would a 18" wheel that weighs 25lbs with a 25lb tire outside diameter of 25.9".......
and a 17" wheel that weighs 25lbs with a 25lb tire with a outside diameter of 25.9" be any harder to rotate?
Food for thought!
