Manually power shifting an automatic
Old Jan 26, 2001 | 08:54 PM
mdeal's Avatar
Has anyone experienced delayed shifting going from D1 to D2 on their automatics, then, ultimately to Drive?
I had my automatic transmisson starting in D1. I had OD off. I floored it from a stand-still, and shifted into D2. There was a couple of seconds delay before D2 kicked in. I was just at 5000 RPM and was expecting the rev limiter to kick in any second since the engine was racing, and I thought it would go past 5000 RPM. Then, the transmission engaged and went into the second gear. I then proceeded to shift to "D" and that transion was more quick.
I had my TCM replaced some time ago, but I thought that would fix delays in "drive" between the 1st gear and 2nd gear shift, totally seperate from D1 and D2 on the gear selector lever.
Could the D1 an D2 shift be another problem or is this ordinary?
PS: I don't want to hear anything about a VB mod.
Old Jan 26, 2001 | 10:17 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Yes, I also get that delay when I manually shift it at 6100... it doesn't engage until 6500-ish.
BTW, get the VB instead.
Old Jan 26, 2001 | 10:24 PM
Loe max's Avatar
1-2 shifts are usually slower than 2-3 or 3-4 shifts. It is suppost to soften the shift. Its normal. Well, it should be normal because you have a new TCM. Like Kev said, shift at 6,100rpm, the car will not go into second until 6,500-6,550 rpm's.
Old Jan 26, 2001 | 11:11 PM
irvine78's Avatar
hmmmm
i don't think you guys should do that..
i mean, i don't think you can shift any faster than the computer...
but...well....guess that's why i bought a 5sp.
Old Jan 26, 2001 | 11:15 PM
Y2KevSE's Avatar
That's the only way we can shift close to redline and use the full <b>222</b>.
Old Jan 27, 2001 | 06:44 AM
UMD_MaxSE's Avatar
Got Bent?
It's normal to experience a delay between the actual hand-shift and the transmission shifting. Thats why you should manually shift up at 6100 rpm or so. That way, the transmission will shift at or close to redline. If you shift too close to redline, you may hit the rev limiter.
Old Jan 27, 2001 | 08:22 AM
Paul6speed's Avatar
This is different then all the previous generations of Maximas'. Since the 2000+ has a higher peak HP, past where the transmission shifts automatically, you need to shift it to take advantage of it. (If you are racing). The problem is that the 5th gen auto tranny cannot take any abuse. (IMHO). So it's a Catch 22. If you want to race a 5th gen Maxima, better get the 5 speed. Why couldn't Nissan have a good transmssion, like the Tiptronic?
Old Jan 28, 2001 | 02:20 PM
unrealii's Avatar
reprogram...
your tcm to remove that delay and to shift at higher rpms... == so you don't look like a stick wannabe
Old Jan 28, 2001 | 02:25 PM
max2kgle526's Avatar
Re: hmmmm
Yeah, I thought that wasnt to good on the tranny. You cant use the full 222 if the cars broke.
Old Jan 28, 2001 | 07:21 PM
slick's Avatar
i dont want to sound like a dolt.....
but whats a VB? is a good thing or a bad thing? do i have one?
Old Jan 28, 2001 | 07:32 PM
UMD_MaxSE's Avatar
Got Bent?
The VB is the valve body. Every auto tranny will have one.
Old Jan 29, 2001 | 07:09 AM
Y2KevSE's Avatar
Re: i dont want to sound like a dolt.....
Do a search (link located at upper right corner of page) and use "vb" or "valvebody" as your keyword.
lowpost99
Oct 26, 2025 06:53 PM
Maximan190
Dec 16, 2015 06:01 AM
cruce91
Sep 20, 2015 10:23 AM
pjgreek
Sep 9, 2015 09:30 PM
videomano
Sep 8, 2015 03:28 PM
