What is involved in ECM/ECU reprogram/flash???
Old Jun 13, 2003 | 08:22 AM
lcf's Avatar
lcf
My dealership is trying to charge me $300 for it.
Old Jun 13, 2003 | 08:34 AM
kratz74's Avatar
Ouch sounds high! Should be less than ah hour. So whatever they charge for an hour or Maybe 2 for labor is plenty unless its warranty work...then free.
Old Jun 13, 2003 | 08:42 AM
Virus's Avatar
Report them to Nissan HQ. The TSB states that it's a half hour worth of labor. To be honest it doesn't take them even that long. The hook a consult II which is a handheld device to the inside port on your car and punch in the update and after a few minutes it's updated. It cost me $37. They told me they would do it for free per the TSB, but they wanted me to put my stock intake back on before they did it. It wasn't worth the effort so I paid the $37.
Old Jun 13, 2003 | 08:49 AM
lcf's Avatar
lcf
Thanks for the input, guys. I know, $300 IS high. The tech also said something about a sensor that had to be replaced as well. Perhaps there was a communication problem between the service writer and the tech. I made it clear to the service writer that I ONLY wanted the reprogram/flash and NOT replace O2 sensors unless the SES lit up again.
I'm trying to figure out if the O2 sensors are really bad or if it's the ECU/ECM.
Old Jun 13, 2003 | 10:10 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
It takes 15-mins. tops.
Old Jun 13, 2003 | 11:30 AM
Virus's Avatar
Your MAF probably needs to be replaced, not your o2 sensor. I'm too lazy to do a search, but someone here created a wonderful list of the MAF part #'s that were having the problem and the 1 that has had no problems. The TSB clearly states that the MAF should be replaced if it is the bad part number. Make 100% sure you don't have one of the falty MAF's. It will definately go bad sooner or later. 2 coworker's wife's just went bad and their cars are completely stock. This is a free fix. If they tell you that they couldn't find anything, keep taking it back to them or find another Nissan Dealer. The MAF is $500.
Old Jun 13, 2003 | 12:25 PM
lcf's Avatar
lcf
Huh? So it's a MAF problem not an O2 sensor or ECU/ECM problem? Even though the codes say it's the O2 sensors?
Old Jun 13, 2003 | 12:39 PM
Virus's Avatar
All I saw that you wrote was about the ECU reprogramming. That is normally associated with the MAF/ECU TSB. I'm sure if the computer said that it was an o2 sensor it was. Sorry for the confussion.
Old Jun 13, 2003 | 12:41 PM
NT2SHBBY
The good MAF is 22680-AM600
Old Jun 13, 2003 | 12:53 PM
lcf's Avatar
lcf
Heh, I see. The reason I want to reprogram the ECU is because it's telling saying the O2 sensors are bad. Unfortunately, many, many 5th gens have experienced this.
There's been lots of discussion about whether the O2 sensors are covered under the powertrain warranty and a lot of other related topics. One of them, interestingly, was started by someone who replaced their O2 sensors and started getting the SES after, IIRC, 3000 miles. It seems to appear that the O2 sensors are not malfunctioning but something else is.
I'm hoping JUST an ECU reprogram will make my SES disappear for good. If it shows up AGAIN, it must mean that the O2 sensors really are bad... OR....... a shady dealership didn't actually reprogram anything? Pretty much, I don't want to fix something that isn't broken... especially when it costs this much $$$.
Either way, I made this pretty clear to the service writer... I don't know what happened. Damned fools.
user 11122324
42
Jul 18, 2022 03:35 PM
mkaresh
Mar 12, 2018 06:48 PM
Marc2theMax
Sep 28, 2015 08:13 AM
FlaMark
25
Aug 28, 2015 10:15 AM
