Check Engine Light
Check Engine Light
Hey everyone have posted for a while but just a quick question, maybe someone could help....my check engine light came on a month and a half ago I would say....and I disconnected the battery. So time went on and then maybe 2 weeks later it came on again.. and ever sense then it comes on every 50 miles or so.. I invested in a OBD 2 reader a couple day ago...I read the code and it read "Catalyst System Efficiency Below Threshold (Bank 1)." Does anyone have any idea what that means, because I know I don't. Thanks for the help.
z
z
Zman,
The short version is.... OBD-II systems use an o2 sensor before and after each catalytic converter. The first sensor is typically responsible for adjusting A/F ratio and the second sensor monitors the converter’s efficiency. The ECM is continuously monitoring the results of each and over time determines how effective (efficient) the converter is. Your ECM has determined one of your converters is failing. A mis-tuned engine can damage a converter quickly. It's probably not something you are able to fix yourself. Not becuase a converter is impossible for a DIY'r to replace, you just want the correct diagnosis. You should probably visit your dealer... be prepared... converters are expensive.
Originally posted by zman187
do you think a intake could have done this???? and is this really going to hurt the engine...I dont have much money so I can't be wasting it on sensors acting up on me
I have 52700 miles on the car
OR, you really have Emissions failure. I would make sure to check up on that TSB.
Good Luck
I would have your problem diagnosed and refuse service if it's a O2 sensor, you should be able to do that yourself. If it's a precat that job is a bit tougher if you think you can hack it give it a go. Once you know for sure what the problem is you can get either part from DAVEB at a much better price than at a dealer.
Maximaman,
I went to the TSB website and I found this...
Make : NISSAN Model : MAXIMA Year : 2000
Service Bulletin Num : NTB00070A Date of Bulletin: MAR 15, 2001
Component: OTHER
Summary:
SOME VEHICLES MAY EXHIBIT A MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0420 (THREE WAY CATALYST FUNCTION) STORED IN THE ECM. *TT
tell me what you think by the way when you read the codes you just get the number part and my code was 0420 thanks
zman187
Component: OTHER
Summary:
zman187
I'm not familiar with the TSB's for 00&01 Max's. Even if this TSB applies in your case you will still need to take it to a dealer. They will then diagnose it and call you with the results. Just try to see if the TSB does in fact apply and whether or not the emissions related parts fall under warranty. This will be the most cost effective way to go about it. Just make sure they don't do any work until you've given them the ok.
You see if the TSB applies the they reflash the ECU and your done (I guess) if it's the precat it needs to be replaced, if it's the O2 sensor it needs to be replaced or it could lead to other problems. Some of the NJ boys should be able to lead you to a good dealer. Just remember to put your stock intake back in.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
