lets say its 86 degrees and 90% humidity??
Old Jun 22, 2003 | 08:51 PM
SERSPECV's Avatar
im going to the track and i wanna know if my car is gonna run alot worse with these conditions?? anybody race with weather like this? and if so how much where there times off by?? any info would help alot.. thanks guys asap im going in a couple of days..
Old Jun 22, 2003 | 11:43 PM
HitManSE's Avatar
Hold crap thats not too good of a condition to run, you want the temp and humidity as low as can be. If your lucky a tail wind as well. Dont expect anything amazing with those conditions.
Old Jun 23, 2003 | 12:21 AM
2001SE's Avatar
espeically if you have an intake, you loose power a lot more with an intake when its hot out compared to the stock airbox
Old Jun 23, 2003 | 12:25 AM
HitManSE's Avatar
True, I remember last summer here in Phx when it was like 110+ at the track. Every1's times were like .5+ sec off from normal. If your on juice it wont effect you much at all since sprat is at like -30 , your just gonna have more traction since it hotter out but if dont have the power to make use of it then summer blows to run a good ET.
Old Jun 23, 2003 | 08:56 AM
specv's Avatar
i can really run .5 or more slower??? i do have intake so wow should i just lower my best time of the day by .5??? is it really that bad or does it vary???
Old Jun 23, 2003 | 09:07 AM
bigdo26's Avatar
hot air = less power. hot air is less dense and less fuel is mixed with it, resulting in fewer ponies to the tires. it works something like that.
Old Jun 23, 2003 | 11:18 AM
2001SE's Avatar
my car with the WAI when its 75+ degrees out is SLOW, no pull below 3k and if i have 2 or 3 people its even worse, its so frustuating i just hate it.
will it better to go back to stock and loose the pull at the top end with the intake? is the difference in pull at the top end THAT good? i forogt since i have my intake on for about a year
Old Jun 23, 2003 | 07:54 PM
HitManSE's Avatar
Last summer my best summer ET was 16.1 @84 (pathetic )
Last winter my best ET was 15.5 @90
The only thing that changed was tires but since my car is an auto it made little diff on my 60ft time. With the new tires I pull 2.4 with the potenzas I pulled a 2.5
TKHanson
Nov 24, 2018 01:39 AM
rbuswell
Nov 12, 2016 04:11 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
97_GXE
Sep 15, 2015 06:47 AM
t6378tp
Aug 24, 2015 07:03 AM
