faster to manual shift or just leave in drive? (AUTO)
Old Jun 25, 2003 | 01:26 PM
skandalouz's Avatar
??? manually shift from 1-2-3-D... or jus leave in drive? from a dead stop?
Old Jun 25, 2003 | 01:28 PM
NT2SHBBY
its always bad to shift an auto tranny manually... leave it in D and go..if you want more "uuumph" off da line, drop to 3, accelerate till u pass whoever u gotta and dump back to "D"
Old Jun 25, 2003 | 01:36 PM
BiggD23
Just to clarify...putting it in 3 basically limits it to 3rd gear correct? So it will shift normally through 1-2-3 but never go into overdrive right? My buddy auto-shifts his 99 Maxima all the time and I'll say this, it's ALOT faster off the line that way. Granted, it's probably bad for the car like NT2SHBBY said but it feels alot faster.
Old Jun 25, 2003 | 01:44 PM
E55AMG2's Avatar
Wat
The auto shifting isnt bad for the tranny, if done properly that is. Just like double clutching a manual, if you mess up, it isnt good for the tranny. So long as you shift the tranny before the rev limiter, you should be ok. BTW: my car was .2 sec faster to 60 when done manually according to my Gtech. (6.6->6.4) It also depends on the year of your max. the 2k2/3's make better times w/ manual shifting. My old 01 didnt make a difference at all.....
Old Jun 25, 2003 | 01:47 PM
Y2KSESteve's Avatar
My car consistently runs 2 to 3 tenths quicker in the ¼ mile when I manually shift it.
Old Jun 25, 2003 | 01:48 PM
bigdo26's Avatar
based on the dyno's i've seen, the engine makes close to peak HP up at redline, so allowing the engine to rev all the way up to the redline, rather than shift at around 6000 or so with it in "D," means that when we do shift to 2nd, the RPMs are higher up, meaning more HP is available. this sound about right?
Old Jun 25, 2003 | 01:49 PM
skandalouz's Avatar
sounds good to me.. i was jus confirming what i thought felt faster...
Old Jun 25, 2003 | 02:17 PM
Blu's Avatar
Blu
the tits
Manual shifting puts you higher in the rpm range than leaving it in drive. Thats why the car is faster when manually shifting. The power actaully starts to go down at 6100-6200 but if you shift then you will land the next gear at a lower rpm which means more lag. Understood
Old Jun 25, 2003 | 02:50 PM
BiggD23
Hey blubyu2k2...I believe you have my red stapler!?!?
Old Jun 25, 2003 | 02:51 PM
Y2KSESteve's Avatar
mmkay.
Old Jun 25, 2003 | 02:59 PM
Blu's Avatar
Blu
the tits
do you have my tps reports ready...
Old Jun 25, 2003 | 03:32 PM
jeremysride2000's Avatar
yeah what he said...
CorollaULEV
30
Aug 9, 2021 08:11 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Trin1j23
Aug 12, 2015 08:31 PM
