OK to do this???
Old Jun 30, 2003 | 06:45 AM
BiggD23
OK to do this???
When driving an auto from a stop...is it OK to rev the engine to about 2k RPMs with your foot on the brake and then let it go from there? Is it bad for the engine or the tranny?
Old Jun 30, 2003 | 06:47 AM
NT2SHBBY
bad for tranny and brakes
Old Jun 30, 2003 | 06:59 AM
BiggD23
Yeah I figured it was bad for the brakes. My buddy does it all the time when racing with his automatic 99 Max to get a better launch. Just wondering if it is bad for anything else.
Old Jun 30, 2003 | 07:37 AM
Padsy's Avatar
Boost.....
I think it cancells out any "good" launch you may have thru the converter.
Jeff92se explaines it well.
Old Jun 30, 2003 | 07:50 AM
02SEinStL's Avatar
I've found it works well on some cars, less on others. In any case I wouldn't do it every launch for reasons noted above. This is a great technique for turbos, but I don't think I would have any luck with my Max...if I really punch it off idle I get quite a bit of wheelspin as it is.
Old Jun 30, 2003 | 09:02 AM
WildmanAL's Avatar
I think I get a beter launch when I do this. How is bad for the tranny? I may see a reason with the brakes, but all you're doing is pressing the gas a little bit and holding your brake in to keep the car from moving. I usually rev up to under 2K though.
Old Jun 30, 2003 | 09:05 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
When you launch, you need to flash the TQ converter, not hold the RPM in place and keep the car from going anywhere with the brakes. Flashing the TQ converter puts much less strain on the drivetrain and brakes.
Old Jun 30, 2003 | 09:11 AM
BiggD23
Dumb question...but what does 'flash the torque converter' mean?
Old Jun 30, 2003 | 09:17 AM
scopium
if u wana good launch ... just put your gear in second and o/d ...
after your launch just stick back in D but keep o/d
02SEinStL's Avatar
I think it means just wait till the second before you take off to "load it up"
Old Jun 30, 2003 | 09:21 AM
02SEinStL's Avatar
Do you mean keep o/d off?
In that case it's just put it in 3, since "D" is WITH o/d
