P1320 Code
Old Jul 12, 2003 | 01:47 PM
ramboz's Avatar
P1320 Code
Just got back from AutoZone. My 2k SE has been misfiring. They pulled one code P1320. But it did not discribe it saying to "Check your owners manual. DTC Manufacture Specific." Does anyone know what this is? I have been leaning toward a bad coil but I disconnected each coil and didn't notice any difference in the idle between any of the six. I'll go to the dealer if I HAVE to.
Old Jul 12, 2003 | 03:16 PM
Maximam's Avatar
I think o2 sensor
Old Jul 13, 2003 | 01:10 AM
Teser's Avatar
Re: P1320 Code
P1320 - Ignition signal primary circuit fault.
Looks like one of the coils went bad. You should have the second code specifying which cylinder is misfiring, then you can replace faulty coil.
I believe that there is a TSB on this. And if your car is still under warranty, and fits the TSB requirements, then you probably can get it fix for free at the dealer. Let me know.
Good luck.
Old Jul 13, 2003 | 04:04 PM
ramboz's Avatar
Thanks! The read out at AutoZone only showed one code and unfortunately I am at 39k so I am out of warranty. I'll have to do some more investigating before going to the dealer. Thanks Again.
Old Jul 13, 2003 | 05:40 PM
Breadman40's Avatar
I had the same problem when I first bought my 2K SE. It was an ignition coil. Like Tesar said, my car also had another code telling me which cylinder was misfiring. My car had 49K on it, but it was covered under the 3000/30 day warranty that the dealership gave me. P1320 is definitly a coil.
Old Jul 13, 2003 | 05:52 PM
cyclecrazy55's Avatar
Try this link. It should answer some of your questions.
http://www.iequus.com/3100.asp?catshort=3100
Check the definitions
Also if your coils are bad the ECU should throw a code telling you which one is bad. Also if you need a new coil, call the guys over at Courtesy Nissan. They have the best prices and tell them your a Maxima.org member.
Good luck.
Old Jul 15, 2003 | 05:37 PM
ramboz's Avatar
Re: Re: P1320 Code
Good luck.
Went to a different AutoZone to see if they saw a second code but they only saw the 1320. Both places turned the ignition key to the on position, but I wonder if it would have made a difference if the engine was running. At this point I have an appointment with the dealer on Monday. But would rather replace the coil(s) myself. Any thoughts how to save $90 just to find which coil is bad? Thanks
Old Jul 15, 2003 | 09:47 PM
My suggestion ,if you want to try it, is to buy 2 new coils (1 front and 1 rear (they are different)) and then place it in each cyclinder to find out which one is misfiring. It will cost you around $90 to $100 dollars for both coils from Courtesy Nissan (the cost of the diagnostics alone). Even after the dealer finds the problem, they will probably charge you an arm and a leg to fix it. If its the coil, I saw a TSB that may help you get the dealer to fix it for free, but thats hit or miss with dealerships. I fixed my problem before I had a chance to check out the TSB. The risk of trying my suggestion is that it may not fix the problem and you may have to end up taking it to the dealership anyway. I found my problem luckily and learned how to change my coils and plugs in the process. You choice. Good luck.
Old Jul 16, 2003 | 09:42 PM
RC03MAX's Avatar
Re: Re: Re: P1320 Code
I havent gotten this code on a 5th gen...but I did experience it on a 1999 GLE....i have a code reader & i kept getting P1320.....the only time I got a coil code was if I checked it immediately after the check engine light went on....if I shut the car off & restarted it, the coil code was gone but the P1320 was still there.....turns out I had a bad coil that was failing intermittently....
hope this helps...
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
