Diagnostic Codes
Old Feb 3, 2001 | 10:50 AM
MaximaKev's Avatar
Does anyone have the diagnostic codes for a 2K? If someone could with a manual could post instructions on how to check the codes for a 2K I would really appreciate it also.
This info may be out there, but I could only find it for older models off of Andi's old maxfaq site.
Thanks,
Kevin
Old Feb 3, 2001 | 06:20 PM
mdeal's Avatar
P0100 Mass air flow sensor
P0110 Intake air temperature sensor
P0115 P0125 Engine coolant temperature sensor
P0120 Throttle position sensor
P0180 Fuel tank temperature sensor
P0325 Knock sensor
P0335 P1336 Crankshaft position sensor (POS)
P0340 Camshaft position sensor (PHASE)
P0403 EGR volume control valve
P0460 P0461 P0464 P1464 Fuel level sensor
P0500 Vehicle speed sensor
P0605 ECM
P1126 Thermostat function
P1320 Ignition signal
P1335 Crankshaft position sensor (REF)
P1605 A/T diagnosis communication line
P1706 Park/Neutral position (PNP) switch
P0105 Absolute pressure sensor
P0130-P0134, P0150-P0154 Front heated oxygen sensor
P0135 P0155 Front heated oxygen sensor heater
P0137-P0140, P0157-P0160 Rear heated oxygen sensor
P0141 P0161 Rear heated oxygen sensor heater
P0217 Coolant overtemperature enrichment protection
P0443 P1444 EVAP canister purge volume control solenoid valve
P0446 P1446 P1448 EVAP canister vent control valve
P0450 EVAP control system pressure sensor
P0510 Closed throttle position switch
P0705-P0755 P1705 P1760 A/T related sensors, solenoid valves and switches
P1165 Swirl control valve control vacuum check switch
P1401 EGR temperature sensor
P1447 EVAP control system purge flow monitoring
P1490 P1491 Vacuum cut valve bypass valve
P0171 P0172 P0174 P0175 Fuel injection system function
P0306 - P0300 Misfire
P0400 P1402 EGR function
P0420 P0430 Three way catalyst function
P0440 P1440 EVAP control system (SMALL LEAK)
P0455 EVAP control system (GROSS LEAK)
P0505 IACV-AAC valve
P0600 A/T communication line
P0731-P0734 P0744 A/T function
P1130 Swirl control valve control solenoid valve
P1148 P1168 Closed loop control
Old Feb 4, 2001 | 02:33 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Someone bored...
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
