Brake upgrade!!
Brake upgrade!!
I've got a question about upgrading your brakes. Do you have to do one of those $1000+ upgrades or can I just get some cross drilled rotors and some better pads? Please help.
'Have to' is a very subjective question....
Me? I definitely 'had' to. Look below to see who made me do it....
And this also depends which car u drive...the 2000/2001s have REALLY marginal brakes while the 3.5 liter cars have better brakes so I guess if u have a 3.5 you can get away with less radical mods whereas if you have a 3 liter car, it depends on your useage model & how lucky u were with the particular car you bought.
I personally am really easy on brakes but even then, I gave up going back to the dealer every 6k miles because my rotors were warping plus I wanted to enhance looks and lighten up the car so I went with a full kit
Here's the real culprit:
Typically you will get two-piece rotors, the
alumimun center section or 'hat' as it's called, the cast iron rotors themselves, slotted and/or drilled or both, the larger -typically four piston- aluminum calipers, a set of pads in the compound you want, braided SS lines to replace the rubber lines and all mounting hardware.
You can get kits in the sub-$1k range that have the calipers and larger rotors but there are one-piece rotors...they do the same job but typically weigh LOTS more than the two-piece rotors.
The 'better' kits with two-piece rotors & four-piston calipers will run from the $1300 range (ala my Wilwoods) to the $2400 range for top-of-the-line Brembos.
Check this site out for lots of info on brake stuff...
www.wilwood.com
www.wilwood.com
Take a look at this thread to see the very nice brakes we're offering. Complete front kits (2 piston aluminum calipers, 12" or 13" slotted & plated rotors, braided hoses, performance pads, brackets and hardware) for under $800. We've got a group deal going on these. Check it out.
Actually cross drilled rotors are worse. Drilling leads to stress cracks in the rotor, which can shorten it's life span and could result in a dangerous situation. That's why we only slot ours. I'm sure others will back me up on this. Here's what cross drilled rotors typically end up looking like.
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
