Remove lighter socket - help
Old Jul 25, 2003 | 12:27 PM
max 2k1's Avatar
Hi
Stupid question here, but I hope someone that has played
with a 2001 (ae) dash might be able to answer this for me.
I have a v1 radar detector, and the part that makes contact
in the lighter socket somehow came undone, and fell into the
left hole that exists in that socket.
How do I remove the lighter socket from the center dash
to get this part back?
Any thoughts? or pointers would be appreciated
Mike
Old Jul 25, 2003 | 12:29 PM
jjs's Avatar
jjs
Re: Remove lighter socket - help
Originally posted by max 2k1
Hi
Mike
Try removing the ashtray. Enough room for your hand back there?
Old Jul 25, 2003 | 12:32 PM
PCGuRu2K's Avatar
Just remove the ashtray. Unscrew the 1 screw in there. And using a flat head just pop out the shift console. Then you'll be able to access the rear of the cigarette lighter
Old Jul 25, 2003 | 01:25 PM
max 2k1's Avatar
follow up
That worked great
Now problem 2
I after putting it together, I pulled it in and id didnt' seem to work
so I plugged it into the rear - above the cup holders - +12v slot.
I think it fell apart again in there - and fell through that hole.
Anyone kno whow to remove the cup holders and get into that area
thanks
Mike
Old Jul 25, 2003 | 01:34 PM
jjs's Avatar
jjs
Re: follow up
That worked great
Now problem 2
thanks
Mike
Screw the whole project and just get a new cord.
Old Jul 25, 2003 | 01:46 PM
max 2k1's Avatar
I agree but
That leaves me without protection for the weekend
I called valentine - they are sending me replacement pieces
- good guys
but I'd still like to know hoe to open that console
anyone done it b4?
thanks
Mike
Old Jul 25, 2003 | 03:43 PM
max 2k1's Avatar
got it
Well that was easy
there is a plastic cover at the bottom of the center panel
armwrest - armwrest open, this pops off
2 screws under that that hold the arm rest in place
take them out and you can see the back lighter, the piece was
just under the lighter, next to that was an opening down to
the cup holder.
I am glad that is over.
Becareful with Valentine lighter adapters
Mike
Old Jul 25, 2003 | 04:05 PM
NYC2SD's Avatar
I removed my rear lighter. Just take a miniature screwdriver and pry around the surrounding moulding. It will pop right out.
Old Jul 25, 2003 | 06:40 PM
mjg's Avatar
mjg
damn dude, bad luck... can't you just split the leads off of one of the lighter and solder or crimp them together instead of this make shift stuff thats ruining your car : /
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
