Woohoo, finally got my intake in, one question though
Old Aug 2, 2003 | 04:51 PM
mad_maxx03's Avatar
After months of waiting (I've had a smile on my face all day) my frankencar w/ the apexi is in. My question is this, they sent instructions, but at the top it says for 2000-2001 Maxima/I30.
I would believe it doesn't matter on the 2002-2003, am I correct?
Really that's all I needed to know.
Thanks guys
Old Aug 2, 2003 | 05:33 PM
clipse's Avatar
Re: Woohoo, finally got my intake in, one question though
Thanks guys
-From the FrankenCar Website-
2002 Maxima, Altimas and I35's
1. Remove the bolts holding the stock air box in and the support bracket on the strut tower.
2. Loosen the clamp on the MAF.
3. Remove the stock airbox with MAF attached
4. Loosen the 10mm bolts holding the MAF to the airbox
5. Place the MAF and o-ring off to the side carefully
6. Disconnect the breather line from the resonator box
7. Loosen the clamp on the Throttle body and pull the rest off.
8. Put one silicone coupler on the throttle body( it helps if you lube the edge with some chapstick or dab of vaseline first), then clamp it down.
9. Put one silicone coupler on the MAF, also lube that too, then clamp it down
10. Using the STOCK MAF bolts, attach the adapter to the MAF and tighten in a criss cross pattern, make sure the o-ring is in there.
11. Attach and clamp the filter to the adapter.
12. Insert the tube into the rubber coupler on the Throttle body side and clamp it down
13. Attach the MAF and filter assembly to the tube and clamp it down.
14. Attach the bracket to one corner of the MAF adapter plate and then the other end to the hole on the strut tower where the bracket for the stock airbox was using one of the shorter stock bolts.
16. Make sure all connections are good and tight
16. Start car, feel that power
Old Aug 2, 2003 | 10:17 PM
Jimmimax's Avatar
Hey I've had my Frankencar and Apexi on for less than a month and love it! Let me know how you like yours, it was worth waiting for! Good luck
BkGreen97
Apr 2, 2016 05:47 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
Johnny9595
Sep 3, 2015 05:18 AM
iflexsteel
Sep 2, 2015 08:04 AM
