automatic trans fluid
Old Aug 3, 2003 | 08:05 AM
hotrod37's Avatar
has anyone used or can reccomend any other automatic transmission fluid other than nissan "d" for a 2002 maxima se
Old Aug 3, 2003 | 08:08 AM
jonbth's Avatar
Has to be Dextron III. I used Mobil 1 fluid in mine.
Old Aug 3, 2003 | 12:57 PM
serin's Avatar
is mobile 1 atf synthetic, a la their motor oil? if so, any real advantages to going synthetic with atf?
Old Aug 3, 2003 | 01:03 PM
Uconn411's Avatar
Yes, by going to synthetic, you reduce the friction between moving parts. Thus, you reduce the wear, and the overall temp of the transmission.
Old Aug 3, 2003 | 02:15 PM
serin's Avatar
right.
i guess i should have asked, is there any tangible difference? i'm referring to the posts in the past that cite inproved gear engagement, not as much 'floating' and such...
as far as the reduced friction/longer life, will this make any difference if i'm regularly flushing my atf? that's a flush, not drain and fill. i've been doing it every 45k-50k. it's prolly overkill, but considering my high miles, i've been a bit paranoid. and if i switch to synthetic, does the same extended use theory hold?
Old Aug 3, 2003 | 09:38 PM
jonbth's Avatar
Yes Mobil 1 trans fluid is synthetic and it meets Dextron III specs. It's easy to change. I'll be draining and refilling my trans fluid every 10,000 miles.
user 11122324
42
Jul 18, 2022 03:35 PM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
