Modding a manual vs. an automatic...
Old Aug 4, 2003 | 08:51 PM
Inarticulate's Avatar
Based on the fact that the auto loses more HP to the wheels than the manual, does the loss stay proportionate when adding mods?
Suppose a mod is advertised to add 10 hp to the wheels. Would both transmissions see the same 10 whp gain? Or would the auto not gain as much?
Thanks.
Old Aug 4, 2003 | 08:52 PM
MaxMafia
Good question.
Old Aug 4, 2003 | 09:10 PM
Can anyone help us?
Old Aug 4, 2003 | 09:24 PM
zipper's Avatar
While I don't have proof to back it up, I'm almost positive that you would lose some power from the automatic. Remember the auto takes a percentage, not a set amount. So I'm guessing that it will always take around 6% (or whatever percent it does take).
-Zipper
Old Aug 4, 2003 | 09:29 PM
Maximam's Avatar
I would assume when advertised it is based off of a manual tranny. But the question is would it add 10hp to whatever baseline it started from? Good question.
Old Aug 4, 2003 | 09:31 PM
MxdOut97's Avatar
each transmission takes a certain percentage of power away from the amount that is produced at the flywheel, so to answer your question, yes, a car with an auto tranny would get less power to the wheels than the manual tranny car with the same mod(s), well im pretty sure if not someone please correct me
Old Aug 4, 2003 | 09:54 PM
KCMichaelM's Avatar
Yes, autos will lose proportionately (sp) more with each mod to the wheels than a manual would. Remember the reasons for loss through the transmission/drivetrain. The biggest is the median of transfer (fluid vs. direct drive), second largest being heat.
Now, if you could add a mod that would not increase the heat output or coefficient of transfer through the tranny, it would be the same. However, you will add heat. Take the example to the extreme... If I supercharged my Max, the tranny WOULD run hotter, and the tranny would have a harder time putting power to the wheels. So, say manuals would get 80whp, an auto would likely gain 65-70whp.
Old Aug 5, 2003 | 12:06 AM
amaxeatinvtecs's Avatar
solution to overheat = VB mod!!!!!!!!!!!
Old Aug 5, 2003 | 12:59 AM
[maxi-overdose]'s Avatar
VB mod is not a solution to overheat...it will add more pressure and more heat to your tranny. a tranny cooler is the solution to overheating the tranny.
this is from the FAQ on maxima.org
How can a torque converter improve my performance and what does it do?
A torque converter is basically the clutch for an automatic transmission. It transfers power from the engine to the transmission gears. However unlike a clutch in a manual transmission, the torque converter (TC) transfers power hydraulically through the transmission fluid. Since the transfer of power is done hydraulically rather than mechanically, more power is lost between the engine and drivetrain. With this mod you actually loose power at the expense of the added stall speed (i.e. more slip before stall speed is achieved). What you get in return is much better torque multiplication which is what makes for stronger launches at wide open throttle (WOT). It will allow you to launch at higher rpms which is only beneficial if you have slicks or drag radials. On regular tires, you'd only spin worse. With sticky tires, you can launch like a rocket which is an advantage especially when your engine is not that responsive through mid range torque. Check out Level 10 or ProTorque for more information.
to solve the power loss thru tranny, you will need a better torque convetor, a more efficient one to transfer more power to the wheel.
from the last dyno, I was able to push 273hp to my wheel @ 10psi on my auto max. Another SC'ed manual maxima put 306whp to the wheel @ 10-11psi after fine tuning, but that car has some engine problem.
Old Aug 5, 2003 | 01:23 AM
thats not so bad @10psi, are u using a vbmod or torque converter as well to hold all that power? how often do u redline, once a day?week?month?? im just curiouse because i dont have enough money to swap to5 spd so im gonna risk boosting the auto,but it does give me more confidence everytime i see other boosted autos on the org.
Old Aug 5, 2003 | 08:05 AM
I have a vbmod but no torque converter. I dun think there is a high efficient torque converter for maxima. I boost daily. usually from 2nd gear-3rd-4th or 3rd-4th just to pass slow traffic. I rarely boost from dead stop. I have about 12k of boost miles since the install in last November.
Old Aug 5, 2003 | 10:46 AM
JMF's Avatar
JMF
The transmission takes a percentage of power, but it is variable dependent of how much power is being produced. Typically, the higher the horsepower, the transmission losses become closer to "fixed."
When I used to work with Camaros, (I know this isn't the LS1 forum, but the principles are the same) stock manual cars typically dynoed higher than automatic cars. But when hp levels got in the upper 300s, the same mods from car to car typically showed the same gain on the dyno regardless of transmission type.
my03maxima
Jul 28, 2024 07:40 AM
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
doctorpullit
Oct 28, 2019 10:58 PM
