Speed Limited after mods ???? . . . . .
Old Aug 7, 2003 | 01:25 AM
MaxVader's Avatar
Before I add the Frankencar and new set of tires I was able to run atleast or close 130mph. Now that I have add the Frankencar and new tires I barely get over 120mph. (I know its crazy to go that fast so don't blaze) Could it be the new size tire 235/50/17??? Or did I do something wrong with the Frankencar. Should I re-reset the ECU. I reset the ECU when I installed the Frankencar. I don't know whats wrong, and its kinda making me mad. If there is a limiter how do I remove it. Or should I check something else all together.
Old Aug 7, 2003 | 06:43 AM
soundmike's Avatar
Very sound, Mike
What tire did you get?
Old Aug 7, 2003 | 06:46 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Re: Speed Limited after mods ???? . . . . .
i would bet its the tire size and the speedo error that comes along with that size. ive got the same size on mine and i noticed my speedometer reads a little low at normal speeds but can be off pretty bad when you get up there. i checked on my gps and im still running the same top speed though.
Old Aug 7, 2003 | 10:20 AM
Maximam's Avatar
Yep tire size, you are running a larger diameter
Old Aug 7, 2003 | 11:35 AM
PCGuRu2K's Avatar
Just go buy a RSM and you'll be able to do 160+mph.. Trust me it's a nice rush
Old Aug 7, 2003 | 12:28 PM
MaxVader's Avatar
Ok if it is my tire size according to the TireSize calculator website. It says that at 60mph I would be doing 60.9mph it should not be a differce of 10mph should it.? I have the Kumho KH11 Tires. And what is a RSM.???
Old Aug 7, 2003 | 12:48 PM
sloppymax's Avatar
speedo error increase the higher you go. a rsm is a rev speed meter made by apex'i. its made for monitoring just about any function of the car and it also allows for removing the top speed limiter.
Old Aug 7, 2003 | 01:06 PM
soundmike's Avatar
Very sound, Mike
At those sizes, a 10mph speedo error is too high. If anything it shouldn't be more than 2-3mph for this particular size.
http://pw1.netcom.com/~sgalaba/tiresize.htm#ustires
Old Aug 7, 2003 | 01:40 PM
MaxVader's Avatar
Where can I get one and how much do they run?
Old Aug 7, 2003 | 01:50 PM
soundmike's Avatar
Very sound, Mike
They run about $220 for the meter alone, another $70 for the G-Sensor and stand if you want it.
Just search for Apexi RSM on google.
Old Aug 7, 2003 | 01:51 PM
sloppymax's Avatar
good price here . if you want a better description go to apexi's site. i think its apexiusa.com or something close to that.
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
