HELP!Torque Steer is killing me!
Old Aug 7, 2003 | 09:41 AM
knightmelodic's Avatar
Hey folks. Need some help. I traded a 98 max w/ S/C and full suspension mods for 03 6speed, which handles like a bread truck. I can drop it and beef the suspension. Add a blower etc. But the torque steer is killing me. If I add a blower the damn thing might just run in circles. The factory LSD is crap. More of a traction unit than a posi. HELP!!!If I can't solve this problem, I'm going for the G35. Thanx.
Old Aug 7, 2003 | 09:47 AM
Maximax2's Avatar
Re: HELP!Torque Steer is killing me!
Solve it completely? No
But when I bought mine, it had really bad torque steer even at medium throttle. Then I figured out I had radial pull from one of the tires, which made the problem much worse. Now, even at WOT, it's more of a question of holding the steering wheel a little tighter, vs. actually steering against the torque. So you might swap your wheels side-to-side and see if that helps.
Old Aug 7, 2003 | 10:06 AM
soundmike's Avatar
Very sound, Mike
Re: Re: HELP!Torque Steer is killing me!
Old Aug 7, 2003 | 10:18 AM
Maximam's Avatar
There is your answer!
Old Aug 7, 2003 | 10:26 AM
MaximaDisciple's Avatar
The overly boosted power steering probably has a factor in the torque steer, but eventually you'll get used to it. Of course the G34 solution isn't a bad one either.
Old Aug 7, 2003 | 10:38 AM
NT2SHBBY
two things to help ALMOST alleviate torque steer:
1) FSTB
2) wider tires...my new 245/45/17's almost completely alleviated my torque steer...
I very rarely feel it now
Old Aug 7, 2003 | 11:07 AM
MarcusJY's Avatar
Man, lift some weights and just hold on to the wheel.
Old Aug 7, 2003 | 11:09 AM
Donkey®'s Avatar
wat
Add a blower huh?
njmaxseltd's Avatar
1) FSTB
Tires play a huge roll in torque steer. Nissan doesn't use the best rubber.
Old Aug 7, 2003 | 11:10 AM
jeepik's Avatar
your're not driving a super handling car,...
keep that in mind and you'll be fine...dont try to overdo what the car is made to do
Old Aug 7, 2003 | 11:18 AM
MaxSE03's Avatar
If you really hate it that much, go for the G35.
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
