***top Speed****
Old Aug 7, 2003 | 09:41 PM
Picasso8750's Avatar
***top Speed****
1)Does anyone happen to know the real top speed of a 2003 Max SE (auto)? I have hear it is 155 mph which is governed. sooooo...
2) How can I take the governor off...can I do it by hand or does it need to be done by computer etc...?
and finally...
3) How fast will a stock 2003 Maxima SE (auto) go without the governor restricting it?
Old Aug 7, 2003 | 09:44 PM
nissan5788's Avatar
1. IIRC Auto is gov. at around ~130 ..search?
2. I think there's a chip out there that'll remove the limiter, not too sure about the company that makes it though.
3. W/o..prbs drag limited like the manuals
Old Aug 7, 2003 | 09:53 PM
lol...thanks...dont wanna search though...i think ill find out the hard way!
Old Aug 7, 2003 | 09:56 PM
what am i saying....i meant...FUN way
Old Aug 7, 2003 | 09:57 PM
scopium
custommaxima.com
Old Aug 7, 2003 | 10:04 PM
Maximam's Avatar
You going for a Maxima land speed record?
Old Aug 7, 2003 | 10:11 PM
mclee45's Avatar
fastest I've gone was 155 on my 2k 5spd. scary as $hiet. slight turn of the wheel feels like a jerk.
Old Aug 7, 2003 | 10:12 PM
lol....something like that....ive been 100 mph in it before which was smooth and effortless....but id like to see what 130 mph is like and see if its really limited to that
Old Aug 8, 2003 | 12:49 AM
HitManSE's Avatar
The 3.5 Auto will top off anywere from 130-140, its due to more of a drag limited combined with the long @ss gear. The 6spd will climb to 155+
Old Aug 8, 2003 | 01:03 AM
GreekMaxima's Avatar
I went 130 with my 2k3 maxima!!!!
Old Aug 8, 2003 | 02:26 AM
MrGone's Avatar
just incase you wanted to know,
1989 SE 5spd, stock, 137mph with more to go, but the tires were only 130mph rated, which my friend didnt think about, arg....
thats 160hp crank
Old Aug 8, 2003 | 06:44 AM
grey2002_ny's Avatar
thats 160hp crank
55mph ;>
Old Aug 8, 2003 | 07:27 AM
Maximax2's Avatar
Re: ***top Speed****
and finally...
Lots of threads on this, and someone else will refute this info, but:
1. SE 6-speed not governed, drag limited (per C&D or R&T test)
2. SE auto not governed (mine went over 130 easily, as did my '95 - others have said they hit a governer at 130 ) GLE and GXE are definitely governed based on the speed rating of the tires
Old Aug 8, 2003 | 09:02 AM
greekmax2k1's Avatar
i have hit 135 in my 2k1 SE auto....but i def think its governed cause its just stays there after....doesnt go up or down...
Old Aug 8, 2003 | 09:48 AM
e34bmw_maxse's Avatar
around 141, mine hit 130 easy. (stock 2k auto)
Old Aug 8, 2003 | 10:08 AM
SR20DEN's Avatar
VQ Wizard
All of these speeds are just what was read on speedometers which are like snowflakes.
Despite what people have seen on their 2k2 or 2k3 auto's they are limited to 130mph. Six speed cars can be as high as 150 under the right conditions but really no more than that. I have tried numerous times to hit 150 and my car simply will not do it. I think the best it has ever done was about 145.
Old Aug 8, 2003 | 10:56 AM
Maximax2's Avatar
SR2, I'm not trying to bash you, but I'm really sick of hearing the "speedo error" argument. I've checked mine with my GPS (including WAAS), and it's off .3 mph at 70, and .6 mph at 100. So the theory is that within 30 miles an hour above a hundred, suddenly it pukes and goes 5+ mph off? Sorry, I don't buy it...
Old Aug 8, 2003 | 11:07 AM
SR20DEN's Avatar
VQ Wizard
You be sick of that all you want but you know it's true. If you don't want people to mention it then you should always say you've checked your quoted speed with a GPS. And it means nothing that your speedometer is correct if it's someone else who's claiming they hit a certain speed by reading theirs. When my car was new my speedometer was as accurate as yours but now I know it's about 5% off because of the smaller tires I have from checking it with a GPS.
Old Aug 8, 2003 | 11:22 AM
KCMichaelM's Avatar
Speedo error *could* be valid... It depends on the weather. My 2k auto tops around 132 on the speedo.. And every radar box I've driven by, no matter how fast, it has been within 1 mph. However other cars can be fun.
My 92 300ZXTT speedo was dead-on (per police radar, a friend) at 115. Now, on a 70 degree day, it would be accurate at 160. (It was a 5-speed and I know how to read a tach...) The one run where I REALLY topped out, I was actually going 181 and it read in the 190's, probably around 60 degress outside. *However*, one time when it was around 35 degrees outside, I was only going about 160-165 and it almost pegged back to zero, approximately 205-210 It sure looked cool!!!
I do not believe my 2k auto is electronically limited. If it is, then it's at 155 where I am never going to reach
Old Aug 8, 2003 | 11:26 AM
Maximax2's Avatar
Okay, maybe I didn't state this clearly the first time, so I'll make it simple this time:
I've checked my 2k3's speedo - as stated
MY 2k3 has broken 130 easily
So MY 2k3 auto SE is apparently not speed limited to 130
Does that mean no-one's auto SE is limited? No, others have said they've hit a limiter
Does this mean YOUR Max (don't know what it is) isn't speed limited? No
Also, I checked with Nissan, who told me that Maximas are speed limited to the speed rating of the tires. That would be 130 for the H-rated tires on the GLE / GXE, and 149 for the V rated tires on the SE (6-speed and auto).
The weird thing is that there are some owners on the forum that have broken 130 in their auto SEs, and others who are equally positive that they have hit a limiter. I've tried to figure out the difference, but there seems to be no common factor, so...
Old Aug 8, 2003 | 11:35 AM
KCMichaelM's Avatar
Seconded that Maximas *are* electronically limited per the ratings on the tires. There are different ECU programs that are based solely on whether are not you have V-rated tires.
Old Aug 8, 2003 | 11:39 AM
SR20DEN's Avatar
VQ Wizard
That's better.
Old Aug 8, 2003 | 12:01 PM
HitManSE's Avatar
That's better.
Old Aug 8, 2003 | 12:12 PM
Maximax2's Avatar
That's better.
Happy to help
Old Aug 8, 2003 | 12:36 PM
Jopa416's Avatar
125 MPH
Pretty effortless to get there and the car had more in it, but I was catching up to slower traffic and backed out.
Old Aug 8, 2003 | 12:42 PM
SR20DEN's Avatar
VQ Wizard
Happy to help
Lets try something else. Can anyone beat my claim of 614mph on their GPS?
Old Aug 8, 2003 | 01:13 PM
well that clears a little bit up
Old Aug 8, 2003 | 01:19 PM
Y2KSESteve's Avatar
GLE/GXEs seem to be governed and the SEs seem to be drag limited.
Old Aug 8, 2003 | 01:38 PM
MrGone's Avatar
You dont know what kind of car SR20DEN has?
I think its pretty safe to say hes a pioneer when it comes to 3.5l based Maxima's. There arent many people on this board who will install nitrous on a brand new Maxima (under warrenty).
nah, Just playing with you. Matt's my hero though
Old Aug 8, 2003 | 01:40 PM
SR20DEN's Avatar
VQ Wizard
The thing is, I wasn't even trying to be a smart@$$. We were on the verge of an argument that I did not want to contine.
Old Aug 8, 2003 | 02:19 PM
h2kFrosty's Avatar
How in the HELL did you go 155 in a 3.0L with NO performance mods?!?!?!?
Bryan
Old Aug 8, 2003 | 02:28 PM
HitManSE's Avatar
Bryan
Maybe YOU can pull that off and actually go well over it but I dont know abou the stock 3.0 Im sure stock the 5spd will pull over 140 but im not too sure about 150+
Old Aug 8, 2003 | 02:30 PM
h2kFrosty's Avatar
You would know if you hit the governor... it's essentially like letting off the gas all of a sudden... You can feel and hear it.
Bryan
Old Aug 8, 2003 | 02:38 PM
h2kFrosty's Avatar
No I assure you I can't go over 130... I have a damn GXE with 15" steel wheels (H rated tires stock), so therefore I'm governed at 130... my car gets to 130 really damn fast and has PLENTY more room to go, but alas it does not... Whats even better is the speedometer reads 133 when the governor kicks in, so therefore I guess I have a 3mph speedo error at that speed... Who knows.
Bryan
Old Aug 8, 2003 | 02:44 PM
HitManSE's Avatar
Bryan
Ahhh crap I didnt know you were a GXE, you see on my SE there is no limiter that im aware of, thats why I stated its drag limited it just goes to 130ish and stays there with the foot to the floor, it doesnt drop off a few mph like you hit a limiter it just stays and does not accelerate. Get and SE Ecu Obviously your ride is a sleeper but with better tires im sure you can pull well over 160 but then again whats the point to go that fast
Old Aug 8, 2003 | 02:50 PM
h2kFrosty's Avatar
I will get an Apexi RSM which removes the governor... Also yeah I do need better wheels/tires, but as far as 160 goes, that will probably be the max speed my car can go (transmission limited)... not a term you see often lol... the 3.0L max's have short 5th gears, so at 160mph my car will be at or in redline...
Bryan
Old Aug 8, 2003 | 04:18 PM
KCMichaelM's Avatar
Transmission limited is the best kind! At least you know you can use the WHOLE powerband. 300zx TT's 5th-gear redline at 181.
What fun, what fun...
Old Aug 8, 2003 | 05:07 PM
koostermax's Avatar
i once...
hit 142 mph on the speedo racing a modified ford focus svt on highway 99 going north through turlock... kept it in 5th and rpm was at 6200ish...6th would have been too tall (i've tried once going south on same highway out of atwater on 6th and took too long to reach 130 mph)
anyway had to shut due to major traffic like quarter of a mile ahead... after the slowdown to 65, it felt slow... what a rush it was though.
Old Aug 8, 2003 | 05:15 PM
kratz74's Avatar
Thats somewhat subjective.
Old Aug 8, 2003 | 06:47 PM
Maximam's Avatar
136mph on my GLE, hits limiter and feels like you turned the ignition key off when it hits.
