Car veers to the right slightly (problem?)
Old Aug 9, 2003 | 04:00 PM
LithiuMax
Got my car about 3.5 months ago, and it has been veering to the right slightly at everyday speeds, and moreso at highway speeds. What's the deal? I hit a hard *** pothole about a week after I got it, on the left front tire.. would that have anything to do with it? What can be done?
Old Aug 9, 2003 | 04:12 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Re: Car veers to the right slightly (problem?)
im not sure about where you live but in NC most roads have a crown to them. the highest point is in the middle of the road so cars naturally drift to the right. i always check the way my car tracks on the highway, so if the road is not a problem then have you had an alignment recently and have you check the air pressure on your tires?
Old Aug 9, 2003 | 05:55 PM
LithiuMax
I doubt that it is the roads, because it can't be EVERY road, heh. I will check tire pressure.. last I checked (about 3 weeks ago) it was in the low to mid 40's. Is that over inflated? I haven't changed the pressure since I bought the car.
How much is alignment, and do I need to have it on a new car?
Old Aug 9, 2003 | 06:13 PM
sloppymax's Avatar
in my opinion 40 is too high unless you checked it while the tires were warm. i check mine when they are cool(not driven on for 4 hours or so) and i keep mine at either 34 or 35. alignment costs vary from shop to shop. my dealer does it for 59 but i bought a lifetime alignment contract for firestone for 99 and i have never had problem with firestone or their work. mileage wont be the determining factor if you need it or not. you mentioned you hit a large pothole which could easily knock it out of spec. if your left sided tires arent a good bit overinflated than the right then i would bet it needs an alignment.
Old Aug 9, 2003 | 06:34 PM
Mom's2kGLE's Avatar
Ditto to sloppymax I bought a lifetime also you figure if you do it twice you got your $ worth plus I live in Buffalo and our roads leave a bit to be desired in the spring so I take it every 6 mos to have it checked. You may also have a slipped belt in one of the front tires try a rotate and balnce depnding of coarse on the cond of the tires. Peace
Lakersallday24
Jun 16, 2019 01:35 AM
Finkle
Sep 27, 2015 09:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
MikesChevelle
Aug 7, 2015 05:57 PM
RealityCheck
Aug 5, 2015 06:18 AM
