BUMBER from 02 to 00
Old Aug 14, 2003 | 07:50 PM
kdharris's Avatar
Does anyone know If the frot bumper and grille from a 02 max will fit a 00 max. I messed mine up and can get the bumper and grille from a 02 max cheap. Also will the fog lights from the 00 fit the 03 bumper.
Old Aug 14, 2003 | 08:56 PM
PhxBlue's Avatar
MK3 Supra and Focus ST
Re: BUMBER from 02 to 00
I may be wrong but i dont think the 02 bumper will fit properly around the headlight area, i think the headlight housings arent different sizes.
Old Aug 14, 2003 | 09:19 PM
MONTE 01&97 SE's Avatar
Fog light are different for sure, totally different part numbers for 00-01 vs 02-03. The 02-03's look larger also.
Old Aug 15, 2003 | 07:07 AM
MaxDoogie's Avatar
the bumper should fit fine, and they didn't make any changes to the headlight area...That is why so many people with 2000's have 2k2 headlights on their car
Old Aug 15, 2003 | 07:13 AM
SR20DEN's Avatar
VQ Wizard
Give it a try. The 2k2 front end looks better than the 2k front end anyway.
Old Aug 15, 2003 | 07:52 AM
PoLo's Avatar
2-Wheelin it...
well at least he'd be one of hte few 2k2's with a NICE aero lip.....
Old Aug 15, 2003 | 07:55 AM
MAKSYMALNY
The bumper won't fit... for one thing, the grilles are a different size between the 2k/2k1 and 2k2/2k3... the other thing, the 2k/2k1 grille is built into the bumper, the 2k2/2k3 isn't.
They are different part numbers because they are different parts... they are not interchangable.
Old Aug 15, 2003 | 07:57 AM
jjs's Avatar
jjs
One way to find out...someone call DaveB and ask.
Old Aug 15, 2003 | 07:59 AM
asu174's Avatar
Clay Aiken has fancy genitals
The bumper should fit. Yes, he will need to buy the 2K2 grille also, but it should be a direct swap.
Old Aug 15, 2003 | 08:02 AM
ToYLeT902's Avatar
JET Speed Lab
Yup
Old Aug 15, 2003 | 08:04 AM
PoLo's Avatar
2-Wheelin it...
Old Aug 15, 2003 | 08:08 AM
MAKSYMALNY
Hey... yes, he has to also buy the grille...
hence, NOT a 'direct swap'. He has to incur the cost of a grille as well.
DUH
Old Aug 15, 2003 | 08:10 AM
jjs's Avatar
jjs
Did ANYONE read his original post?
He said he can get both cheap and never implied he would want to get away with a bumper swap only.
Old Aug 15, 2003 | 08:14 AM
MAKSYMALNY
well, then, my answer was based on a bumper swap only and comments that the bumper would fit... the bumper will fit ONLY if the grille is swapped out as well.
Old Aug 15, 2003 | 08:18 AM
jjs's Avatar
jjs
Old Aug 15, 2003 | 10:54 AM
asu174's Avatar
DUH
A "direct swap" is defined as being able to switch out parts without having to MODIFY anything on the bumper or car.
Old Aug 15, 2003 | 11:01 AM
MAKSYMALNY
No, that's misleading information.
"direct swap" of a bumper means take one off, put the other on.
Without also swapping out the grille, big problems.
-R
Old Aug 15, 2003 | 11:03 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I've recently talked with DAVEB about doing this and it looked like a few $0.70 clips was all that was required, however you'll have to buy 2K2 foglights and mod the electrical plugs to make them work.
The swap should be pretty straight forward, besides the foglamps and MAYBE the 2K headlamps. I have 2K2 headlamps, so that wasn't a concern.
meccanj98
Sep 16, 2015 06:06 PM
adkim
Oct 7, 2002 11:45 AM
Titleistprov21
May 14, 2002 11:32 AM
elgatomax
Mar 6, 2002 03:20 PM
elgatomax
Mar 6, 2002 02:09 PM
