Do our 5TH Gen. Maxes require a timing chain?
Old Aug 15, 2003 | 07:35 PM
rubman's Avatar
Since I haven't spent much time on here lately, thought I'd ask because I seem to remember forum members saying in the past that our VQ's didn't need timing chain replacement. Anyone know for sure? Thanx in advance for any help.
Old Aug 15, 2003 | 08:12 PM
Maximax2's Avatar
Re: Do our 5TH Gen. Maxes require a timing chain?
Timing chain in VQ's, not a timing belt. Unlike timing belts, does not need replacement.
Old Aug 15, 2003 | 08:15 PM
rubman's Avatar
Re: Re: Do our 5TH Gen. Maxes require a timing chain?
Guess I've been away but the courtesy of maxima.org members is the same as it's always been. Thank you so much for the rapid reply. This is why this forum works so well. It's the members that make it perform.
Old Aug 15, 2003 | 08:32 PM
E55AMG2's Avatar
Wat
Actually, after a certain number of miles, the timing chain is usually replaced. This is somewhere between 120-160k miles though, so no worries anytime soon.
Old Aug 16, 2003 | 07:18 AM
Jer's Avatar
Jer
Old Aug 16, 2003 | 08:22 AM
jeepik's Avatar
timing chain is a duty free item unless it stretches beyond the capability of the tensioner, or completely breaks
its not like a timing belt which wears out over time.
Old Aug 16, 2003 | 12:07 PM
E55AMG2's Avatar
Wat
Unless nissan has invented some sort of miracle timing chain, you will need to change it eventually. I had to do it on my 89 mercedes at 162k miles.
Old Aug 16, 2003 | 01:36 PM
SkoorbMax's Avatar
I was always under the impression that it did not need replacement unless something was explicitely wrong with it or one had reason to believe it otherwise needed replacement. I don't think there is a recommended change interval, whether it's 100k or 200k or 500k as long as the chain is still good to go.
Course what do I know
Old Aug 16, 2003 | 01:41 PM
jeepik's Avatar
and why did you have to change your timing chain???
maybe you should talk to some ford and chevy truck guys who have over 300K on their engines without chaing the timing chains??
Old Aug 16, 2003 | 02:26 PM
E55AMG2's Avatar
Wat
i guess it depends on how you drive. That car was meticulously maintained but driven hard. Very hard. It may be part of their particular maintenance schedule. The engine was also an Inline 6, but that shouldnt make any difference.
Old Aug 17, 2003 | 01:24 AM
95emeraldgxe's Avatar
they have a timing chain, but thats something that you probably will never have to worry about
Old Aug 17, 2003 | 12:08 PM
Jer's Avatar
Jer
It doesn't matter if you baby the gas like an egg or brick it - you do not need to change the timing chain. Period.
Old Aug 17, 2003 | 12:51 PM
Aggie Jurist's Avatar
eventually the system will fail. It's not the chain usually, but the drive shaft sprocket which wears. It should take about 200k to get there, but eventually it will fail.
Old Aug 17, 2003 | 06:10 PM
E55AMG2's Avatar
Wat
I had the actual chain begin to stretch. That and the sprocket had to go. As for the VQ, It must be a really low tension chain for it never to be changed.
maxinout93
Oct 27, 2015 01:29 PM
Finkle
Sep 27, 2015 09:53 PM
Team STILLEN
Aug 10, 2015 04:29 PM
laparka66
Aug 6, 2015 09:36 AM
