Rear Brake Job
Old Aug 21, 2003 | 02:30 AM
machplane's Avatar
Rear Brake Job
Hi, i am pretty new to this website and i am pretty new at working on my car. Can anybody give me some pointers on how to do a rear brake job for a 5th Gen Maxima. Thanks
Old Aug 21, 2003 | 05:58 AM
mingo's Avatar
as in new pads? or upgrade? only upgrade u can get for the rears are basically rotors and stainless steel lines and pads. if you want to change the pads, you'll have to buy a special tool that pushes the piston back in, it screws back in.. you gotta take one bolt off the top of the caliper and the whole thing swings down. it's real simple.
Old Aug 21, 2003 | 05:17 PM
machplane's Avatar
Thanks for advice, but i wasn't able to obtain that special tool you were talking about. The guy at the auto parts store told me to use a pair of pilers to turn loose the piston then hand twist it back in, is that advisable?
Old Aug 21, 2003 | 06:48 PM
binz's Avatar
I used to use a c-clamp for all my brake jobs.
u can get it at any hardware store: home depot, lowes, ace, etc
Old Aug 21, 2003 | 07:06 PM
00MaxSE's Avatar
Pointy Elbows
Yep
Old Aug 21, 2003 | 07:26 PM
hct67's Avatar
Push Piston Back In?
What do you mean you will have to push the piston back in. I took off the fronts to paint the calipers and never pushed the piston back in, when I finished the fronts I did the rears and once again I never pushed the pistons back in. What will happen if I didn't push the pistons back in. I eman they weren't sticking out or anything and when I put it all back together I bled the fronts and then the backs! Did I do something that could have caused some problems?
Old Aug 21, 2003 | 09:05 PM
Max_5gen's Avatar
Yes, I did mine this way - used needle nose pliers.
Old Aug 21, 2003 | 10:14 PM
thomasd cook's Avatar
I got a square box shaped universal tool with little nubs on every end. The little nubs grip the piston and then you can attach a ratchet with an extension. DO NOT USE a C-clamp on the rears. The fronts can be compressed but the rears must be turned back in.
The only reason HCT didn't have to push his pistons in is because he didn't install new pads so the piston was still at the same spot to put them back on.
Old Aug 22, 2003 | 01:09 PM
Rgamfn1's Avatar
Machplane, let me know how it works out. I'm planning on doing my own rear brake job in the next week or two.
Old Aug 23, 2003 | 12:52 AM
machplane's Avatar
Could you tell me where you obtained that box shaped tool, that would be really helpful Thanks
Old Aug 23, 2003 | 08:49 AM
00MaxSE's Avatar
Pointy Elbows
Old Aug 23, 2003 | 09:06 AM
kwd2kSE's Avatar
Got mine from O'Reilly auto parts. It's a universal tool for use on most rear disk brake systems. I would think most all auto parts stores should have this.
Old Aug 23, 2003 | 01:57 PM
young1976's Avatar
Yea, my brother used needle nose pliers to twist the piston back into the caliper on his 96 Taurus. Seems most if not all cars with rear disk brakes and mechanical parking brake has this type of setup...
Old Aug 23, 2003 | 09:15 PM
machplane's Avatar
Well, i did them today and fortunately a friend of mine knows a guy who works as a mechanic at a Infiniti dealership, so he let me have access to the garage. And i tell you it's better have that brake tool using a pair of pliers. One thing to remember is to make sure you align the indentations on the piston correctly so the new pads can go on the caliper, otherwise the pad won't fit in.
i just went on this website and found the rear disc piston tool for 12.95
http://www.extremetools.net/miva/mer...ode=BRAKE_disc
Old Aug 23, 2003 | 10:59 PM
young1976's Avatar
Good find, now when I need one, I'll just order it. That's pretty cheap.
Old Aug 24, 2003 | 01:23 AM
That's the tool!
Old Aug 24, 2003 | 01:47 AM
This part should be available at local auto parts store pretty cheap. Check it out.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
