Anybody know what this CEL code means?
Old Aug 21, 2003 | 11:21 AM
Regime's Avatar
The non-postwhoring Org member
I have a buddy with an 02 Max that is throwing this code P1572. I haven't been able to nail down what this means, as I don't have a manual to look it up. Any help would be great.
Also Anybody in the bay area that has a 84-Present Ford vehicle, I just gained access to an offical Ford ECU reprogramming tool/OBD II scanner. With this tool we can tweak your timing, security settings, reprogram keys and fobs, etc..... IF anybody is interested let me know. I can also pull and clear all OBD II codes from most vehicles.
Thanks guys
Old Aug 21, 2003 | 11:25 AM
2002 Maxima SE's Avatar
P1572 Motor Drive Module (MDM) Temperature Signal Circuit Low Input although other manuals point to a Brake Pedal Switch Circuit.
Old Aug 21, 2003 | 11:43 AM
Regime's Avatar
Thanks man, What manual did you get that out of, and what are the "other" manuals that point to the brake circuit?
Old Aug 21, 2003 | 01:59 PM
It's all on the web. Just look up OBD-II codes. Nissan has there own set of codes as well that are generated with the generic codes.
Old Aug 21, 2003 | 04:50 PM
Regime's Avatar
Anybody have a Manual for the 2002-2003 Maxima? The code definitions for P1572 on the web are either for GM or FORD not Nissan. I can't seem to find what it means on the Max on the web anywhere.
Old Aug 21, 2003 | 05:26 PM
KCMichaelM's Avatar
Hmmm... Not that this helps anyone, but I looked up this code in my 00 service manual and it is not there
Old Aug 21, 2003 | 09:19 PM
Max_5gen's Avatar
When the brake pedal is depressed, ASCD brake switch is turned
OFF and stop lamp switch is turned ON.
ECM detects the state of the brake pedal by this input of two kinds
(ON/OFF signal).
DTC Name:
P1572 1572 ASCD brake switch
Detecting Condition:
When the vehicle speed is above 30
km/h (19 MPH), ON signal from the
stop lamp switch and ASCD brake
switch are sent to the ECM at the
same time.
Possible Cause:
I Harness or connectors
(The stop lamp switch circuit is
open or shorted.)
(The ASCD brake switch circuit is
open or shorted.)
I ASCD brake switch
I Stop lamp switch
(The ASCD brake switch or stop
lamp switch circuit is open or
shorted.)
I Incorrect stop lamp switch installa-
tion
I Incorrect ASCD brake switch
installation
I ECM
Source: 2k2 FSM. ASCD stands for "Automatic Speed Control Device".
jmlee44
Oct 2, 2022 02:13 PM
maxinout93
Oct 31, 2015 02:04 AM
zmcneely13
Sep 26, 2015 02:26 PM
