in the 1/4 mile if u spin alot off the line get off the gas and back on it how much
Old Aug 24, 2003 | 11:17 AM
ga2000's Avatar
in the 1/4 mile if u spin alot off the line, and than get off the gas and back on it how much time do u loose doing this? im talking about getting off it quick and than back on it than waiting for the tranny to kick back in and go.. let me know if u can guys
Old Aug 24, 2003 | 01:39 PM
JoesMAX's Avatar
if you spin a lot off the line youre screwed either way... but you cant let off the gas and then gas it again, you will lose a lot like that... if anything gradually bring your foot off the gas
Old Aug 24, 2003 | 03:52 PM
ga2000's Avatar
so if i ran a 15.1 to a 15.2 spinning and than getting off it and than back on it i should be in the 14s right?
Old Aug 24, 2003 | 04:05 PM
JoesMAX's Avatar
well what was your 60' time?
Old Aug 24, 2003 | 04:40 PM
ga2000's Avatar
it was high 2.4s and 2.5s
Old Aug 24, 2003 | 04:51 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Holy crap. Get down to a 2.0 '60 and you easily have a mid-low 14 second car.
Old Aug 24, 2003 | 05:49 PM
JoesMAX's Avatar
you say that like a 2.0 on street tires is simple
Old Aug 25, 2003 | 09:44 AM
ga2000's Avatar
id be happy witha 2.2 or a low 2.3 60ft. its hard to get there, i never knew an automatic is this hard to launch the right way lol.. on the street its a 14 second car.. because i dont spin alot, on the track the tires just scream which puts me into a low 15 second car.. i WANT the slip to prove im in the 14s, but the launch is hard help guys im going back to the track soon.. how do u launch your 02 and 03s? with stock tires.
Old Aug 25, 2003 | 02:10 PM
JoesMAX's Avatar
learn how to launch a 6 speed and the automatic will be a joke... when i was at the track this guy with an 02 altima 3.5 came with us, and he let me run his car once and i pulled a 2.21 60' time.. first time driving the car let alone launching it. i ran a 14.754 @ 93.65 on that run, but the car didnt really seem that fast to me
Old Aug 25, 2003 | 02:22 PM
ga2000's Avatar
i have a spec v that has a 6spd, i know the difference from launching an auto and a stick lol.. but bro for an auto this thing isnt easy, u have to feather the gas pedal on this auto, otherwise u get way to much wheel spin, just like on a stick.. when u ran the auto altima how did u launch that car?
Old Aug 25, 2003 | 04:54 PM
ga2000's Avatar
x
Old Aug 25, 2003 | 04:57 PM
Y2KSESteve's Avatar
Get new tires if you're having that much of a problem with launching.
Old Aug 25, 2003 | 05:04 PM
ga2000's Avatar
if a stock 03 with those tires can run high 14s with the stock tires than an 04 can with stock tires.
Old Aug 25, 2003 | 05:10 PM
Y2KSESteve's Avatar
True, an 02-04 auto can reach 14s easy, but you seem to be having a traction issue. New tires would help that.
Old Aug 26, 2003 | 04:19 AM
JoesMAX's Avatar
i power braked but i didnt bring the revs up much at all... on the last yellow i let off the brake with my left and gave it gas with the right but i didnt just slam the gas.. when i took off i made the slightest chirp with the tires, the wheels barely spun at all
Old Aug 26, 2003 | 04:32 AM
spirilis's Avatar
Lower the tire pressures? I recall someone mentioning they had a good day at the track with the tire pressures down to 22-24psi...
Old Aug 26, 2003 | 08:54 AM
ga2000's Avatar
i might lower it to about 25 front and 40 in the rear, but well see thanks for all your advice guys
Old Aug 26, 2003 | 11:48 AM
ga2000's Avatar
c
what where your tire pressure set at?
Old Aug 26, 2003 | 11:54 AM
Y2KSESteve's Avatar
Pump the rear tires to max before going to the track and make psi adjustments to the front tires while you're at the track.
Old Aug 26, 2003 | 12:14 PM
ga2000's Avatar
ok the max in the rear is 44 from whats on the tire, so i would set it at like 40 psi.. front im thinking 25 psi, but the lower u go doesnt that hurt top end power?
Old Aug 26, 2003 | 12:17 PM
Y2KSESteve's Avatar
At WOT having your tires low in the front really isn't going to hurt your ¼ mile time...
Old Aug 26, 2003 | 12:38 PM
ga2000's Avatar
hmm i thaught it did, ok ill take your advice, whats the lowest you have gone in the front
Old Aug 27, 2003 | 03:11 PM
JoesMAX's Avatar
Re: c
im not sure what pressure he had it set at, i dont think he lowered it though
Old Aug 27, 2003 | 03:22 PM
ga2000's Avatar
i had the fronts at 28 psi and the rear at about 32....
Old Aug 27, 2003 | 03:25 PM
ga2000's Avatar
but isnt it a waste of time lowering stock tires at the track though? i just dont get the concept of lowing tire pressure i dont wanna hurt my top end. its a matter of like low 15s and high 14s lol
JRod28
Dec 29, 2023 09:56 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
