trunk question
Old Aug 28, 2003 | 08:44 AM
hockeyghst's Avatar
trunk question
in the trunk there r black caps with a little plastic hook holding the carpet inline. i need to remove the RH side tail light, but this is not my car and i dont want to force this black peice out. do i just pull on it or does it twist off?? thanx guys
Tom
Old Aug 28, 2003 | 09:02 AM
soundmike's Avatar
Very sound, Mike
Look at it closely, there's a notch on the sides where you can pull the top-portion off. Once this is pulled out enough, the rest of the plastic clip will just fall off.
To re-install, make sure the top is all the way out again - insert the clip and push on the top to lock it in place.
Note: DO NOT, pull the whole clip as a whole using just the handle/hooks - you will break the clips that way.
Old Aug 28, 2003 | 09:07 AM
hockeyghst's Avatar
ok im preety sure i understand what ur saying...when i was looking at it, it seemd like there is a little notch where u can inster a small screwdriver and pop it up.....i know what ur saying now.
next question.....for anyone that is...
this car is almost a year old. i know the tail light is gonna be a ***** to remove since it has that black gooey crap on it. i was thinking about heading it up from the inside to get it soft and pull the tail light out. is this a good idea?
Tom
Old Aug 28, 2003 | 02:39 PM
hockeyghst's Avatar
bump...
Old Aug 28, 2003 | 03:25 PM
Max2000SE's Avatar
Honestly I dont think heating it up will make a difference...That stuff is there to keep out water and such, most likely that will just make it more of a mess b/c it will just ooze around...Good luck
Old Aug 28, 2003 | 04:10 PM
PoLo's Avatar
2-Wheelin it...
jush push man
i'm serious
there are 3 screws also holding in the taillight, so don't forget those. but yeha, just push it hard and slowly it will begin to give way, if you see that goeey stuff start to spread, then cut it wit a knife. there'e a lot there, so cutting some off aint' an issue. keep on pushing and it will eventually come off. good luck.
Old Aug 28, 2003 | 09:29 PM
hockeyghst's Avatar
thanx guys i will try that
Tom
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
Socalstillen
Sep 26, 2015 12:01 PM
