Interesting Thread
Old Feb 12, 2001 | 06:32 PM
UMD_MaxSE's Avatar
Got Bent?
There is some discussion going on in the General Forum about a tranny mod that essentially boosts line pressure to the maximum giving harder, quicker shifts. Here is one of the threads:
https://maxima.org/forums/showthread...threadid=23536
What do you guys think? It's easy enough to hook up. I have a few potentiometers lying around at home so I may try it. Definitely looks interesting though. The poor mans VB mod...
Old Feb 12, 2001 | 06:38 PM
UMD_MaxSE's Avatar
Got Bent?
Here is a thread with some pics:
https://maxima.org/forums/showthread...threadid=23553
Old Feb 12, 2001 | 06:57 PM
Loe max's Avatar
Looks interesting and cheap. But I won't do it unless the modification has some realiable history. I guess I'll wait and see if you guys have any problems with your transmission
Old Feb 12, 2001 | 10:36 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Don't do it because your vb will be pushing the fluid at full pressure... which is bad.
Old Feb 12, 2001 | 10:41 PM
MrBurner's Avatar
damnit kev, finally something good comes along and you have to go and ruin it....
Old Feb 12, 2001 | 10:56 PM
Y2KevSE's Avatar
My bad... actually I thought it was the another post about the tranny where the person disconnected something (forgot what it was called, but I know what it is). It sounds interesting, but Just don't turn it all the way to the left for too long.
Old Feb 13, 2001 | 11:01 AM
mzmtg's Avatar
Minister of Silly Walks
Well, after a day of driving with this setup...I love it. I have it set just a little firmer than stock. It takes all the hesitation out of the shifts without make them super harsh and clunky like when I turn it all the way up. Still have the MIL glaring at me though...
Old Feb 13, 2001 | 12:19 PM
MrBurner's Avatar
so kev or anyone with automotive expertise...is this going to hurt my tranny at all? what are the short term/long term effects
Old Feb 13, 2001 | 12:52 PM
mdeal's Avatar
mzmtg,
Which valve are you fooling with your setup? I looked at the ESM, and there are several "valves" which seem to control parts of the same thing. The AT part of the ESM is pretty involved, complicated at times.
Do you have more specifics as to what you did?
Y2KevSE's Avatar
Old Feb 13, 2001 | 02:34 PM
Paul6speed's Avatar
They did something similar on TV
Check out Crank and Chrome from 2 weeks ago.
http://www.crankandchrome.com/previo...week_1.27.html
They used a device to increase the line pressure, causing the tranny to shift quicker and more firmly. They recommended a trans oil cooler to go with it.
Old Feb 13, 2001 | 05:59 PM
mzmtg's Avatar
Dont do it like I said, my **** caught fire.
Back to the drawing board.
https://maxima.org/forums/showthread...threadid=23746
Old Feb 13, 2001 | 07:54 PM
Y2KevSE's Avatar
Old Feb 14, 2001 | 07:34 PM
edadams's Avatar
Sounds neat but my tranny doesn't need any trouble. Just had it fixed!
Old Feb 15, 2001 | 06:35 AM
mzmtg's Avatar
Here's what I'm gonna do. Since this "mod" is setting off my MIL, I'll just grab the code and see what it means. This should give me an idea as to what part of the tranny control this is affecting. I should have results this afternoon...after class.
Old Feb 15, 2001 | 06:43 AM
MarkF's Avatar
This sounds very similar to the B&M Electric Shift Improver that is out there for variuos GM and other trannies. I have it installed on my 95 Caprice LT1, and the sole purpose is to electronically fool the PCM into applying a much higher line preassure all the time. The result are quick shifts.
The B&M attaches to two lines on the PCM so I'm not sure if the process here is identical or not, but the B&M has been used for years by many people with no side effects.
Good luck
Mark F
Old Feb 15, 2001 | 07:07 AM
mzmtg's Avatar
The difference here is that the TCM isnt just raising the pressure, it is failing safe and applying maximum pressure all the time. This works great for full throttle upshifts, but it makes all part throttle shifts extremely jerky and rough...Hence the switch.
Old Feb 15, 2001 | 07:31 AM
mdeal's Avatar
There is a shift improved kit available for our Maximas, similar to the B&M product. See my parts page, and look at the "transmission" section: http://www.fourthrock.com/maxima/2k_parts_list.html
One day I am going to purchase and install, but it is too low on my list at the moment.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
