Hey Everybody whats your idle?
Old Sep 16, 2003 | 09:16 AM
mcfalcons15's Avatar
Mine is
2002 SE auto
33,800 miles
idles a little over 1 when I start it up after its been sitting a while
then drops to in between .6 and .7
Old Sep 16, 2003 | 09:22 AM
sorcereur's Avatar
Totally normal. Mine is 2k3 6speed. 24k miles and same scenario. Although most of the time it seems to be idling around 500 rpms
Old Sep 16, 2003 | 09:31 AM
nismotech's Avatar
2k2 6spd w/ 16000Miles
at warm up period it idles at 1200RPM, then drop to around 500 or 600RPM after warm up. I think thats normal.
Old Sep 16, 2003 | 09:37 AM
semaxgo2k1's Avatar
5-6 hundred at op. temp.
I have a 2k1 5-speed SE and I turn 4k @ 95mph and 3300-3400 @ 80mph. This is my first m/t Maxima, are these figures high or right on target?
Old Sep 16, 2003 | 09:38 AM
kcowden's Avatar
Its normal.
Old Sep 16, 2003 | 10:28 AM
E55AMG2's Avatar
Wat
Depends, auto or manual. Also A/C on or off, and is the steering wheel straight ahead. All of these (amongst other things) have an effect on the idle speed.
Old Sep 16, 2003 | 10:38 AM
SkoorbMax's Avatar
2k, 56k miles. 1400 rpm when cold and 650-700 when warm.
Old Sep 16, 2003 | 10:42 AM
Luquire's Avatar
2k1 with 53k miles and 1300rpm at start and 700 after warm up
Old Sep 16, 2003 | 10:43 AM
bigdo26's Avatar
2k2 GLE 18k miles 600-700 warm.
Old Sep 16, 2003 | 11:15 AM
spirilis's Avatar
2k SE 36k miles mine idles around 1000-1500 while cold, 600-700 while hot
Old Sep 16, 2003 | 11:38 AM
CCS2k1Max's Avatar
2k1 5 spd. 40K (ECU flashed at 28K). Idles ~1000rpm cold, ~600 rpm warm.
Old Sep 16, 2003 | 11:43 AM
AKM2k5's Avatar
tad under 500 after putting in synthtic
Old Sep 16, 2003 | 11:46 AM
chigga's Avatar
2k2 beautiful gate shift automagic 15k round 600
Old Sep 16, 2003 | 11:56 AM
jeepik's Avatar
2k2 6 speed... 13,000 miles when cold at 1100rpms. when wamred up around 600 or so
Old Sep 16, 2003 | 12:11 PM
ToYLeT902's Avatar
JET Speed Lab
i idle between 200-500
Old Sep 16, 2003 | 12:37 PM
MiniRX7's Avatar
I idle at about 400-700 ..
I even had the idle bumped upwards... but still it sticks around 500
Old Sep 16, 2003 | 06:49 PM
nismaniac's Avatar
2003 SE 4600 mi ~1100 cold, ~700-800 warm (AC off)
Old Sep 16, 2003 | 07:03 PM
CCx's Avatar
CCx
2000 SE, just turned 40,000 miles.....1100-ish on cold start, 750-ish after it gets warmed up....juuuuust right
Old Sep 16, 2003 | 07:46 PM
dannodotcom's Avatar
My Idle is
2K SE Auto, if dash tach is accurate at low end (debatable), it's about 750 at op temp. On every car I've had with an auto tranny I've decreased the idle RPM because they were always set too high IMO. Haven't touched my Max yet, but probably will drop it a bit, down to 600 would be just about right. The main reason I like a low RPM is the braking, it's much easier on the brakes to come to a stop when your idle is low, pads will last much longer, especially if you do a lot of city driving. To save some wear on the brakes during a hard stop (for whatever reason, like a red light) I will sometimes put tranny into neutral, easier to stop.
Dannodotcom
Maxboy23
55
May 1, 2025 06:09 PM
02PearlSE
Feb 1, 2016 12:37 AM
f.matejaiii
Sep 21, 2015 12:09 PM
blakkheartt12
Sep 17, 2015 08:11 AM
DrVee
Sep 4, 2015 12:18 PM
