Condensation in Rear Clear Lens . . .
Old Feb 14, 2001 | 05:35 PM
y2kse's Avatar
Has anybody figured out yet how to keep the driver's side rear clear lens from gathering moisture? Mine looks like it's constantly sweating on the inside of the lens.
Old Feb 14, 2001 | 06:13 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Not yet...
Old Feb 15, 2001 | 04:25 AM
mdeal's Avatar
I am presuming it is the piece which housing the bulb, and not the lense itself. I say this because everybody's left side gives them trouble, or so I think it is only the left.
Old Feb 15, 2001 | 07:07 AM
Y2KevSE's Avatar
Seems like only the left side has problems... the condesation happens between the outer clear and the inner clear.
Old Feb 15, 2001 | 07:34 AM
mdeal's Avatar
I thought about moving the right side to the left, and seeing if condensation would form, but I really don't want condensation in both, presuming it is the connector piece. That would definetely tell us for sure if it was the lense or the "connector".
Old Feb 15, 2001 | 08:38 AM
Y2KevSE's Avatar
Not possible to do that... check out the picture:
<img src=http://www.autodynamic.com/images/New_Folder/nm00cb.jpg>
Notice the "blurp" on the wider ends? If you flip the marker the other way around, the "blurp" in the bottom will be above midpoint (below if the "blurp" was on top to begin with). Sorry, I can find the correct words for that "blurp."
Old Feb 15, 2001 | 08:59 AM
y2kse's Avatar
Hey Kev . . .
I know you take the lens apart to do your front clear conversion. Would it be possible to do that with the rear clear as well? If so, you might be able to glue everything back together and get rid of the problem.
Just a guess.
Old Feb 15, 2001 | 09:45 AM
Y2KevSE's Avatar
Re: Hey Kev . . .
Just a guess.
Ooooo... scary thought. I don't know how the rear markers are, but the front markers' lens are glued on super tight. Someone took off the lens without breaking them, but it took a long time. Your idea is possible! My bulb hasn't blown yet, so I guess I won't try until then.
Old Feb 15, 2001 | 10:15 AM
Loe max's Avatar
Re: Re: Hey Kev . . .
Just a guess.
I'd say it took a long time Why don't you guys take out the clear corners and pour some water in it to locate the "hole" that is causing this. Once you find it, glue on some silicon sealant.
Old Feb 15, 2001 | 10:55 AM
mdeal's Avatar
I guess I just got reeeallll lucky when I installed mine since the "blurb" was not a problem. Are you talking about the pointy pieces on top and bottom? You can turn upside-down and install on the opposite side.
Old Feb 15, 2001 | 11:20 AM
Y2KevSE's Avatar
I thought the "blurp" (located on the other side of the pointed end) as not centered. Here's another picture
<img src=http://wwwcsif.cs.ucdavis.edu/~chin/images/Maxima/lights/1a.jpg>
Draw an imaginary line across the marker horizontally. Notice the pointy "blurp" on the right side is slightly higher than the midpoint of that edge? Am I hallucenating again?
Old Feb 15, 2001 | 11:51 AM
mdeal's Avatar
Maybe we put them in wrong and they are leaky now?
I suppose it does look a little off center...I'll look when I get home.
Old Feb 15, 2001 | 12:34 PM
irvine78's Avatar
hmmm...and i thougth i was the only one with leaky lenses...
now that just made me feel alot better now....
Old Feb 15, 2001 | 01:06 PM
Maximizd's Avatar
I have not noticed this problem
with my rear clears as of yet. They have been in for several months, but then again, I don't use the car every day and it is usually covered most of the time (when I'm not driving it, of course, unlike the Enterprise rent-a-car commercial where they actually *DO* drive the car with the cover on!).
Old Feb 15, 2001 | 03:13 PM
RBa's Avatar
RBa
Wow.... I thought I was the only one with this problem.... Well...that's what happens when it's made in Taiwan. I've also noticed that they are kind of loose and they wobble. Anyone else?
Old Feb 15, 2001 | 06:21 PM
Y2KevSE's Avatar
They could fit a little tighter.
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
doctorpullit
Sep 10, 2015 06:33 PM
ef9
Sep 5, 2015 11:18 PM
