Cattman VQ30DE headers pics - for ALL 95-01 Maximas/I30s
Originally Posted by IceY2K1
Cattman is releasing the 2K2+ Y-pipe, so don't hold your breath on a long-tube headers. It just wouldn't make business sense.
G35c? As in buying one?
Im starting to lose interest im my car again.
ECU, headers, cams, nitrous......eh?
The G35C or sedan w/6spd would be sweet, however I can't see justifying the hit.
Good luck though!
Good luck though!
Good luck though!
Good luck though!
Now that I have seen pictures of the production Stealin headers these Cattman headers put them ina distant second place. Hopefully the production Cattman headers will look as good as they do in the photo.
Those ARE production headers. He has batches made at a time, not just one and he's said they are on the shelf ready to ship.
Unless you're talking about the 2K2+ headers, which aren't going to be out for a LOOOOONG time.
The Cali spec aren't going to be any different as long as the FRONT Cali 02-sensors reach the Fed locations.
The rears are the only ones that need to be moved FOR SURE, but he can't incorporate that into the design. They MUST be located down-stream of the main cat, ie in the B-pipe.
My advice is to have a local muffler shop weld in two 02-bungs in your b-pipe NOW. Then extend the 02-sensor wires(3-each?) and relocate the 02s to those new bungs. By then someone should have installed the headers and you can order and install them.
Originally Posted by maseo77
im ready to get them as soon as there are cali specs available
That's correct, however the headers eliminate the front precats, so you have to move the rear 02s behind the main cat, ie b-pipe, to keep the ECU happy.
Same thing people did for the Cali-Fed converison. Check for DesertPearl's post in the How-To's.
i thought on a cali spec the rear O2 sensors were b4 the cat not in the b pipe...... i know my 2 O2 sensors are on the y pipe right b4 the main cat.
Originally Posted by [maxi-overdose]
it would be nice to see a dyno graph of an SC maxima with cattman header and cat-back.
any tips on removing the rear manifold?
im about to get my 2k2 headers installed tomorrow or do them myslef... havent decided. the rear manifold is the only obsticle.... pretty tight fit... *is it necessary the replace the mainfold studs (per trusted mechanic)?* thanks
will
hes talking about the STILLEN HEADERS for the 2k2. i sent him pics of the headers that i received on wed........waiting to get installed. cattman headers do look rather appealing compared to the stillen ones. but too bad they aint for the 3.5l .... either way i look at it gettin rid of my rattle in the front pre cat is worth the $900+ considering nissan quoted $1307 to reaplace the front pre cat (said that my RT high flow caused too much air flow which caused the honeycomb inside to "break away" WTF......) ill post impressions of the header/y-pipe combo when the install is complete!
brian what is the diameter of the outlet at the cat end of the y-pipe?
what diameter is each indiviual tube.... i want to say that there might not be a big difference. i have the stillen headers sittin around right now if u have any questions. i would post pics but hosting them is a pain.....
will
I don't know if this is a temporary work around they are using to help fill commitments for orders that have been placed and future versions will be done differently or not. Only time will tell.
Do you know how reliable these o2 signal generators are? Is there a potential for the engine to start running very rich or lean given the ecu is always trying to make adjustment based on these readings?
And Ice I read through this twice, if I missed it let me know. I don't see where Brian said these are production and he's ready to ship. His web page hasn't been updated showing these yet either...
Also anyone know where Ethan is? I'm surprised he hasn't chimed in yet.
Originally Posted by Cattman
Price is $750. All gaskets and hardware needed are an extra $20. These are on the shelf, ready to ship and will fit ALL 1995-2001 VQ30DE engines.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
bigfrank
Oct 1, 2015 12:51 PM
. For a price of $900 they expect you to splice O2 wires which in reality the kit should come with OEM connectors on both sides.
