Maxspeed Springs - problems after less than a year
Old Sep 30, 2003 | 04:36 PM
Burton069's Avatar
I got the springs last year, and for the last month I noticed something weird. I pulled out of a spot, turning all the way to the left, and heard like a "springing" sound. There doesn't look like there's anything wrong, but this is bothering me. Anyone else get this with aftermarket springs?
Old Sep 30, 2003 | 05:23 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
if its a popping sound then it could be a bad strut.
Old Sep 30, 2003 | 06:11 PM
2k2kev's Avatar
It's chrome alright...
you've had the springs a year and you assume it's them that's causing the problem? Did your year have the bad control arm? What about struts? Might there be something wrong with the wheel? Are the lugs tight (all of them!)? Is there something stuck in the wheel-well?
There are dozens of reasons... when you figure it out be sure to let us know.
Old Sep 30, 2003 | 06:41 PM
BioMaxDDS's Avatar
I just noticed the same thing recently, i had maxspeed for about 1 1/2 yrs now with stock struts.
whenever i turn the steering wheel all the way to the left, i'll notice some kind of sound...kinda like griniding sound.....help
Old Sep 30, 2003 | 06:44 PM
sloppymax's Avatar
i had a popping noise when turning right with stock springs and struts. they replaced the driver front strut and the noise went away. it then began to happen with the passenger front so they replaced it as well. i didnt mind either repair since both were covered by warranty. i then replaced the springs with maxspeeds and struts with gr-2s. if you hear it at low speed turns when you turn almost to lock then most likely its a bad strut.
Old Sep 30, 2003 | 06:57 PM
Burton069's Avatar
I guess it might be the strut then. Im going to bring the car in next week for 30K I know they're gonna gimme hell.
Old Sep 30, 2003 | 07:01 PM
KLOOGY's Avatar
L33t BMW Drivah
I have a similar sound. It did it with my stock struts and with my new Tokicos , it still does it. It only does it when I turn the steering wheel all the way.
Old Sep 30, 2003 | 07:02 PM
Burton069's Avatar
Yeah only when I turn it all the way it does it.
Old Sep 30, 2003 | 07:05 PM
2k2nyc's Avatar
Same here, mine usually happens when its raining out. I think it's related to a bushing or something. BTW, I have H&Rs and Tokicos
Old Sep 30, 2003 | 07:06 PM
KLOOGY's Avatar
L33t BMW Drivah
Its not to be blamed on the Maxspeeds.... It must be coming from somewhere else.
Old Sep 30, 2003 | 07:07 PM
Newman's Avatar
ditto. its only when i turn the wheel all the way to the left. mostly when im pulling into or out of a parking spot. though its more of a moaning/creaking sound. i have H&Rs on stock struts.
although, in the last couple days i stopped my car as i was pulling into a parking spot and i noticed whenever the steering wheel would hit the bump stop at its limit, it would make a metal clanging sound. i did it about 4 or 5 times consecutively.
Old Sep 30, 2003 | 07:15 PM
2k2nyc's Avatar
I was told by someone that the sway bar end links may be worn.
Old Sep 30, 2003 | 07:21 PM
KLOOGY's Avatar
L33t BMW Drivah
Yup, mostly on a left hand turn here too .
Old Oct 1, 2003 | 04:12 AM
maximum_rpm_nyc
Look under the car there is a 'stop' a plastic cap on the end of a fairly long bolt. The piece I am talking about is facing towards the back of the car on the steering knuckle. If you look towards the control arm you will see a curved piece and I believe it was the left side the plastic cap is missing, and it will rub and cause like a bad creaking sound. Go to Nissan and get one of those caps, they are very fragile and twist on, not push on. I found out the hard way.
Also on lots of 2Ks, the upper strut mount on the right side tends to go bad and make a rubberry-friction sound. I had mine replaced under warranty.
Old Oct 1, 2003 | 04:24 AM
njmaxseltd's Avatar
Spring pop noise comes from the spring binding and releasing as you turn your steering wheel. It's caused by improper spring seating in the upper perch, incorrect assembly of the spring & strut components or a sticky strut bearing.
The key is that the assembly lines up correctly, the spring compresses evenly and the whole assembly rotates freely on the strut bearing. I've seen Maxspeed springs rust up as well as sit slightly bowed after they have been compressed on the car.
Bottom line is YGWYP4, there a cheap spring, they ride like crap, they don't even give a nice drop. I have no clue why you guys like them.
Old Oct 1, 2003 | 04:53 AM
busakiller's Avatar
Mine would make that noise on the driver side when I was backing out of my driveway... I jacked my car up to look at what could be causing it and I sprayed some lithium grease around the sway bar bushing and it stop... It's something you can try and see if it helps
Old Oct 1, 2003 | 05:19 AM
soundmike's Avatar
Very sound, Mike
Interesting conclusion. How about those who have H&R's that mention experiencing the same thing?
Old Oct 1, 2003 | 07:11 AM
2k2kev's Avatar
just another case of someone who has something else and thinks he's better because of it
Old Oct 1, 2003 | 07:17 AM
BLKMAX005SPD's Avatar
thats what i have...i just block it out becuase i don't wnat to spend anymore money.
everytime i cut the wheel hard it makes a popping sound
is that bad or good
Old Oct 1, 2003 | 08:22 AM
MaximaSe2002's Avatar
yeah i have the same problem with mine it just started doing it recently
Old Oct 1, 2003 | 08:55 AM
IWNTMORHP!!'s Avatar
CAN YOU PUT IT ON THE WALL?
same here, and i am starting to get lots of squeeks on roads that are far from perfect. the end cap is the source of the metal creeking in the left turn...mine is also missing the cap..2nd one now. the right side cap is also pretty close to going too. i don't recall if they charged me for the 1st replacement, but if they did it was a nominal charge. try the cap and some lithium spray grease and hit all the friction points and that should cure most of the probs, and protect you for the 1st part of the winter. hope that helped
Old Oct 1, 2003 | 09:12 AM
ColdSHO's Avatar
i got the same prob, but if mine pops then my alignment goes way off, its deff the right front, both used to do it, but i took to back to my guys, they said they didnt sit right, im gonna go back again and get the last one set in right, third times a charm, im on stock struts with maxspeeds, anyone else with this setup getting a bouncy ride? i think i need new struts.
Old Oct 1, 2003 | 10:00 AM
yeah...slightly bouncy. i need new struts though, so it is understandable. you may have tie-rod probs if you are getting your alignment all jacked up when you are turning to the stops...i agree something isnt right.
Old Oct 1, 2003 | 02:06 PM
ghostrider17's Avatar
Stock setup here.
Same left turn under acceleration - grinding sound.
It's not even consistent - hot or cold.
It like that infernal Cam Chain grinding on the cold morning start-ups that Nissan says is "normal".
When I hit 36001 miles, I'm SURE it will be ABNORMAL.
gr
Old Oct 1, 2003 | 03:00 PM
soundmike's Avatar
Very sound, Mike
Originally Posted by ghostrider17
It like that infernal Cam Chain grinding on the cold morning start-ups that Nissan says is "normal".gr
There's a TSB out for that already
Old Oct 1, 2003 | 06:24 PM
radpp16's Avatar
MAXSPEEDs with aftermarket STRUTS
WHICH IS SOFTEST!!!??
I want the closest to STOCK FEEL.
How is the GR-2 + maxspeed ride?
TOCKS + MAX??
AGXs + MAX?
ANyone in NYC or NJ so i can get a test drive.
THanks
ROger
Old Oct 1, 2003 | 06:50 PM
KLOOGY's Avatar
L33t BMW Drivah
I disagree with you 100% . I have had Eibachs , before on 2 cars, and as far as you calling the springs cheap , I think you're wrong. I would pay whatever the price is , as long as I know it was a good product. I have had my Maxspeeds for 40k + miles , and I am happy with them. I have ridden in Maxes with Eibachs and Teins as well as other spring combos, and there is not a HUGE noticable difference. If you want to judge them by the price, go ahead. as far as YGWYP4, its true many times. I am one who never cuts corners. I like to do things right the first time, but there is a lot of overpriced crap out there too... I may not be slammed, but I dont want to be. I think they provide a fairly even drop. Just my .02 cents.
Old Oct 1, 2003 | 07:35 PM
doublea's Avatar
Many installer forgot to put back the rubber sleeve that prevent the coil spring to be metal on metal, so whenever you extend the steering wheel to the maximum, it kind of skeak, that's because the coil spring rub on the metal plate it sit on.
Cheers
AA
Old Oct 1, 2003 | 07:37 PM
KLOOGY's Avatar
L33t BMW Drivah
I have the ruber sleeves, they are called spring insulators by Nissan. I still get that noise. I even ordered an entire set of new ones.
Old Oct 1, 2003 | 09:02 PM
Triple8Sol's Avatar
I miss the .org!
I almost always prefer big brand-name stuff, but when enough people share their positive experiences, I definitely take that into consideration. In the end I got Maxspeeds and they gave me no problems or noises.
Only reason I got rid of the Maxspeeds is because I liked the look of the Tein drop more.
Old Oct 2, 2003 | 07:38 PM
maximum_rpm_nyc
Save some dough and get JICs or Tein Coilovers.
Toss in some WSP SFCs and you will never have an issue again, ever. I promise.
Old Oct 2, 2003 | 08:44 PM
Burton069's Avatar
Well besides this incident (even thought it might not be related) im happy with the Maxspeeds. The drop is good for me. But about fixing that problem, im bringing my car in next week. What should I say? I don't want them to void the warrenty by saying "the springs caused the problem." Last time I brought the car in, he's like "why did you put all this stuff on the car...springs, strut bars" etc.
Old Oct 3, 2003 | 05:20 AM
soundmike's Avatar
Very sound, Mike
JIC's or Tein Coilovers are not a choice for most of us who just wants a good drop while not affecting the ride quality that much. After all, a lot of people who got the Maxima also got it for the comfort.
And chances are, a good percentage of people who do get the Coilovers never see track time in the life of their Maxima. And at that rate, they also probably never really experience the full capability of such setup.
Old Oct 3, 2003 | 06:09 AM
NT2SHBBY
Firstly, I don't agree with you at all....I feel my maxspeeds were well worth it. It's been 5000 miles now with them on and no problems...I hear some noises every now and then, but nothing any louder or more annoying then the damn dash rattles that I have..
bottom for you is that I feel ur hatin on us cuz we got the 3.5's and u don't...
Old Oct 3, 2003 | 09:03 PM
KLOOGY's Avatar
L33t BMW Drivah
Ive put over 40k now on them......so I think I can make a good judgement.
Old Oct 3, 2003 | 09:10 PM
looslip's Avatar
Horra!!
Are you on stock struts and shocks?
Old Oct 3, 2003 | 09:16 PM
KLOOGY's Avatar
L33t BMW Drivah
Not anymore. I got Tokicos about 6k miles ago.
Old Oct 3, 2003 | 09:20 PM
looslip's Avatar
Horra!!
I guess I mean to ask, did the stock parts get blown by the lowered springs? I ask cuz I just bought some Maxspeeds and I've been holding out on installing them until my next paycheck where I'm getting some GR2's.
Old Oct 3, 2003 | 09:21 PM
KLOOGY's Avatar
L33t BMW Drivah
I didnt blow anything with them. I just felt like it was time to upgrade. Actually, by adding the Tokicos, my car droped at least another 1/4 inch all around.
Old Oct 3, 2003 | 09:23 PM
looslip's Avatar
Horra!!
nice, thanks!
