Possibility of 2k2 swap to better transmission?
Old Oct 8, 2003 | 12:38 PM
rumblehead's Avatar
i was wondering if it is possible to swap the 2k2 to a better manual transmission. Skylines have getrags but since it's rwd or 4wd, is it not possible to modify a transmission to work with the maxima fwd? Or is there a high quality fwd transmission? I'm confused:: I'm not sure what is involved in a tranny swap.
Old Oct 8, 2003 | 12:43 PM
Jeff92se's Avatar
I'm needing a caw
My head hurts after reading that.
Old Oct 8, 2003 | 01:18 PM
stockacura's Avatar
He wanted to know if '02-'03 Maximas was like the Skylines. With all the possibility and potentials, Skylines has with mods.
But to answer his question, no, there aren't any performance company that manufacture high performance 6 speed or 5 speed tranny for '02-'03.
You can go to tranny rebuild shops and have them rebuild your tranny stronger with better internal gears/parts/syncros.
Good luck!
Peter
Old Oct 8, 2003 | 02:24 PM
Audtatious's Avatar
Bandwagon Lover
LOL @ Jeff
Yeah, there is no way to modify a Gertrag style tranny to work with a FWD platform. Nor can you take the internals and expect them to fit in the tranny of the Maxima. Of course, if there was enough $$ thrown away, anything is possible.......
Old Oct 8, 2003 | 06:54 PM
MiniRX7's Avatar
Um.. what makes you think the tranny is weak?
its nothcy as hell but its not a weak tranny by anymeans.. I heard the 2k2/2k3 trannies are pretty tough!
Old Oct 8, 2003 | 08:16 PM
Nyc2kMax's Avatar
man!!!!!!!! when you have a lot of time on your hands you can think of some crazy stuff..... lol... that just put a smile on my face.........
Old Oct 8, 2003 | 10:04 PM
SR20DEN's Avatar
VQ Wizard
Sure, any RWD tranny will do fine. And the best part is that you'll only need one slick at the track. It's called OWD.
While you're at it you should consider getting a race prepped Powerglide because all the cool kids are doing it. People are putting much power through them and running some purdy quick times.
Old Oct 9, 2003 | 06:35 AM
tonylittell's Avatar
WANNA RUN IT?
guess it depends on your view of whats "tough"...ive had 2 trannys put into my 03 already....(yes 2 ...original and then 2 new ones for a total of 3 in 1 year)
ive drivin manual transmissions since i was 15(32 now) so i know how to drive them
by far the weakest one ive ever owned
Old Oct 9, 2003 | 06:41 AM
SR20DEN's Avatar
VQ Wizard
The gears themselves are plenty strong enough. The only problems with this gearbox is the sorry a$$ 3rd gear synchro and the notchy shifting.
Old Oct 9, 2003 | 06:55 AM
MaximaMan77's Avatar
Does the extra shift to 4th needed in the 6spd make much difference in 1/4 times?
If so would there be a fitment issue with trying to put a 3rd. gear from a 5spd in there?
Old Oct 9, 2003 | 07:01 AM
Donkey®'s Avatar
wat
Jetrags. Anywho...I have no issues with my tranny. Get a VB mod and go to town.
Old Oct 9, 2003 | 07:16 AM
stockacura's Avatar
Last time I was at the drag strip, I ended up in higher trap speed when going to 4th. I trapped about 97mph on 4th. Once I left it on 3rd, I got about 94mph. Strangely my time was about same for both ~ 14.7, mind you, my launches were irregular.
Peter
Old Oct 9, 2003 | 10:52 AM
2k2-blk-6spd's Avatar
Wow, me too!
sctludwig
Sep 1, 2022 01:32 PM
RinconI30
Nov 10, 2015 10:55 PM
The Wizard
24
Oct 1, 2015 08:47 PM
I<3 A32's
Sep 10, 2015 11:07 AM
maximusrising
Sep 2, 2015 09:55 AM
