Stillen Headers Dyno Results
Old Oct 14, 2003 | 01:52 PM
  #81
str8acura's Avatar
a totally stock maxima should dyno before and then after with the headers. that would be the best way to see if there are any gains.
Old Oct 14, 2003 | 02:30 PM
  #82
Quicksilver's Avatar
OT n00bs FTMFCSL
A baseline is a baseline...if you have all kinds of mods and dyno it, then add the headers (in addition to the mods) and dyno it, it'll serve the same purpose...
Old Oct 14, 2003 | 02:35 PM
  #83
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Normally I'd agree, however with the eManage there are too many *unknowns* that could potentially skew the results.
Actually, I'd PREFER the "baseline" dyno be done on a car with an intake, high flow cat, and catback, but DEFINITELY not with any piggy-back engine management black boxes.
Old Oct 14, 2003 | 06:02 PM
  #84
WILLSE's Avatar
i dynoed today and lets just say im not happy post more when i have time.
will
Old Oct 14, 2003 | 06:06 PM
  #85
IceY2K1's Avatar
TEASE!!!!!!
WILLSE
will
Old Oct 14, 2003 | 06:13 PM
  #86
Colonel's Avatar
Old Fuddy Duddy
Originally Posted by IceY2K1
TEASE!!!!!!
WILLSE
HEY!!! Get back to work and bring my HW li back online so I can do yet MORE OT! NOW!
Old Oct 14, 2003 | 06:14 PM
  #87
OT n00bs FTMFCSL
E-manage always screws things up I agree that anything that piggybacks with the existing ECU is not the best setup. That's the entire reason I'm spending so much time/money on my turbo setup and going with some kind of stand alone management system (just don't know what)...
Old Oct 14, 2003 | 07:32 PM
  #88
WILLSE's Avatar
TEASE!!!!!!
WILLSE
CHECK MY THREAD GUYS!!!!!!!
will
Old Oct 14, 2003 | 09:15 PM
  #89
HitManSE's Avatar
will
This is called being lazy...how about a link to your thread to keep every1 from having to look for it CLICK
Old Oct 14, 2003 | 11:11 PM
  #90
WILLSE's Avatar
LOL http://forums.maxima.org/showthread.php?t=256034
will
Old Oct 15, 2003 | 07:59 AM
  #91
studman's Avatar
The ECU has a bad over-compensating algorithm in the air/fuel mixture.
I'm scheduled to get back on the dyno soon. I'll be tuning the car for regular street driving, then for race driving.
Here's a screen shot from the E-Manage:
E-Manage Screen Shot
Please note that the values listed are not my final values, but they are just an idea of how the unit works.
In the middle portion of the screen, the blue boxes down the left side of the table are where your throttle position numbers go. With the software running in "OFFLINE" mode (not currently connected to the unit), it won't show the throttle position, as the measurements are stored in the actual E-Manage itself, not in the data file. But if it was "ONLINE", then you'd see numbers in those columns.
Here are the audio/video clips of the dyno runs with the headers, WSP B pipe, CarSound Cat, and FlowMaster 60 Series muffler.
WAV Sound Clip 1 (6.4 MB)
WAV Sound Clip 2 (6.2 MB)
WAV Sound Clip 3 (5.5 MB)
WAV Sound Clip 4 (5.4 MB)
MP3 Sound Clip 1 (886 KB)
MP3 Sound Clip 2 (852 KB)
MP3 Sound Clip 3 (773 KB)
MP3 Sound Clip 4 (736 KB)
Video Clip (15.3 MB)
Audio/Video clips courtesy of E55AMG2
Old Oct 15, 2003 | 09:21 AM
  #92
IceY2K1's Avatar
What is "Total Airflow Adj."?
Also, can you put up the same screen shot from your FINAL dyno of 216.8hp/223tq?
Can you "zoom" in on ONLY the area your TPS=100%? In the screen shot example you posted thats 21.3sec-35.5sec..
Old Oct 15, 2003 | 09:48 AM
  #93
brianc's Avatar
studman,
Gotta tell you, I'm finding this very interesting.
Thanks for the excellent documentation.
Brian
Old Oct 15, 2003 | 12:02 PM
  #94
studman's Avatar
IceY2K1: The graphical portion of that screenshot is the final run with the headers. If you look, you'll see that the title for that box says headers-15.LGD, where the upper box says headers #14.GSC. The final table is still stored in the E-Manage.
The "Total Airflow Adjustment" is nothing more than a visual indication of the percentage of reduction. It's basically a Real-Time Display of what's in the chart.
Here's the E-Manage Image from the peak run.
As you can see, the TPS won't register 100% for some reason. I've got version 1.20 software running on the E-Manage, and I just received 1.36 today. I'll get it uploaded before my next set of runs on the dyno.
Once it's installed, I'll re-calibrate the TPS setting again.
I put the cursor at the peak RPM reading. That picture is all the further that the software will let me zoom in. I narrowed down the selection to the actual pull, which should match the dyno run.
Old Oct 15, 2003 | 09:26 PM
  #95
studman's Avatar
I am scheduled to re-tune on Saturday morning. I'll also be moving that day, so don't expect the results to be posted until sometime on Sunday. If I get a chance to post them earlier, I will.
The car is running 10920931x better now. It's finally 68° outside and the car pulled like crazy... it was nice shifting into 3rd gear around 80 MPH tonight.
More details later this weekend. (FYI - This was also posted in WILLSE's thread).
Old Oct 15, 2003 | 09:59 PM
  #96
juice's Avatar
Headers
trust me you gained power
http://forums.maxima.org/showthread.php?t=256334
Old Oct 15, 2003 | 10:07 PM
  #97
BLKMAX005SPD's Avatar
holy **** dude...
you car sounds AWESOME
i love it
Old Oct 20, 2003 | 08:14 AM
  #98
studman's Avatar
UPDATE:
Ok, I can't scan the results just yet, as I just moved this weekend and the scanner is still packed up.
After having the plugs replaced and a PC cleaning done, I went back to the dyno to re-tune.
My results are:
Pre-Dyno Peak HP (Run 13): 217.8
Post-Dyno Peak HP (Run 43): 218.9
Pre-Dyno Peak TQ (Run 13): 231.1
Post-Dyno Peak TQ (Run 43): 225.9
As far as the tuning... the car doesn't like 12.5:1. It's much closer to 13.5:1, with a 0.5 variation depending on the RPMs.
The curves are very similar between the before and after runs, but the before runs are just a tad higher than the after. The headers do seem to help out in the upper end, but they sacrifice the lower end slightly.
As far as the non-dyno results, I definitely notice a difference. Before I had them install, I couldn't chirp second gear because of my sticky Yokohoma tires. After the install, I can chirp second gear again. The car's weight is also less, but I don't know exactly how much.
Once I scan the image (in the next few days when I find all my computer cables, etc), I'll edit the top post and let you see the differences for yourself.
I won't make it to the track anytime soon, but I'll get there the first chance I get.
Old Oct 20, 2003 | 08:22 AM
  #99
studman's Avatar
Here a snapshot from the DynoJet RunViewer of the 2 runs. I'll post the actual dyno up when I get it. The RunViewer's numbers are never correct when compared to the actual printed DynoJet results.
Old Oct 20, 2003 | 08:31 AM
  #100
SR20DEN's Avatar
VQ Wizard
If you want this thing perfectly tuned you may want to tune it on a Mustang Dyno.
Old Oct 20, 2003 | 08:34 AM
  #101
HitManSE's Avatar
Holy ****, its definetly louder! Has the metallic sound to it, line mine did w/o the resonator.
Well good luck with the track, thats gonna be the true test.
Old Oct 20, 2003 | 09:17 AM
  #102
Blu's Avatar
Blu
the tits
looks like the ecu will be next on my list if I buy anything at all.
Old Oct 20, 2003 | 10:49 AM
  #103
Lumbee1's Avatar
Either that or Cattman Y-pipe.
Old Oct 20, 2003 | 10:59 AM
  #104
2k2MerlotSE's Avatar
JUVIN's ride
The car looks and sounds much nicer in person. I had the opportunity to meet STUDMAN this weekend and all I can say about his ride is WOW!
He was kind enough to take me for one HE!! of a ride.
The handling is on a dime, and it does not sound ricer. I was very impressed, espesically his knowledge on tuning/modding/DRIVING. "He is one hell of a driver".
You can tell he has put a lot of time and heart into it.
STUDMAN: Once again thanks for one he!! of a ride. I appriciate you taking some time out your busy weekend schedule for me.
Old Oct 20, 2003 | 11:29 AM
  #105
IceY2K1's Avatar
You can get BOTH for CHEAPER withOUT the install hassle.
Stillen Header = $899.99
Cattman Ypipe + TS ECU = $299 + $495 = $794
7100rpm rev-limit! Only downtime without the ECU sucks.
Old Oct 20, 2003 | 11:36 AM
  #106
OT n00bs FTMFCSL
That might be the way to go then...
Old Oct 20, 2003 | 12:12 PM
  #107
IceY2K1's Avatar
"might"?
Anyone worried about WARRANTY work should consider this route IMO, since it's much easier to rip off a Y-pipe in a hurry, then headers.
Don't even think about headers and a warranty repair, if you are paying someone to install them.
Old Oct 20, 2003 | 12:25 PM
  #108
amaxeatinvtecs's Avatar
this is off topic but youre sig caught my interest where in ft/lauderdale do u live, ive never seen any modded 5th gens in that area, im in weston,black max w/stillen lip
Old Oct 22, 2003 | 10:20 PM
  #109
Mick Max's Avatar
Wild at Hurt
Just a crazy thought, but I have been so stumped as to why the power loss? The stock cast iron manifolds and precats would dampen the power pulses from the exhaust right at the engine. The new headers would take away most of that dampening.
Could this trigger the knock sensor and retard the timing?
A possible explaination as retarded timing would reduce power.
Hope we can solve this because I want headers.
Old Oct 23, 2003 | 02:04 AM
  #110
03BlkSETE's Avatar
Yeah this has been brought up already. I don't think it has been completely ruled out but it doesn't seem likely.
Old Oct 23, 2003 | 06:11 AM
  #111
MaximaMan77's Avatar
Although it was brought up the people testing haven't looked, or at least posted, at what the timing is doing during their pulls. While studmans charts look fairly normal Will's doesn't, this could be what is causing his huge dip at 4.2k... I find it quite interesting that the dips happen with-in 400-500 rpms of the secondary opening up.
Justin, do you have an obd2 reader? If not do we know who in the area does? Maybe we could go with Will the next time he goes to Balanced. Having logs of the runs should help diagnose the problem.
Old Oct 23, 2003 | 06:14 AM
  #112
SR20DEN's Avatar
VQ Wizard
I agree and think someone needs to put this problem in the hands of Technosquare and see what they can do, if anything, with it.
Old Oct 23, 2003 | 06:37 AM
  #113
If we were able to supply TS with some data that would help too wouldn't it? I'm not sure that's I'm asking.
If we could log different parameters during different pulls. By keeping the things monitered to like 3 should keep the latency low. rpm, timing & MAF are the main things to look at. But we could switch it up during different runs. This data can be given to Stillen & TS.
Also during Will's pulls they kept losing the signal from the coils, out of 6 or 8 runs and switching coils for most of them they only got 2 clean charts.
Old Oct 23, 2003 | 07:11 AM
  #114
studman's Avatar
When Will dyno's his car again, have them turn the the RPM signal reader around (upside down) on the same plug. I had the same problem with mine, and I asked out of curiosity if they would flip it over. That keeps the RPM reader accurate.
For the dyno shop, they should insert the plug UNDER the wire, then around - NOT OVER the wire, then around. The shop should know what to do.
As far as my timing, I am currently advanced to +17° BTDC. When I hooked up the scanner to the car (on the 2nd dyno - after the plugs were changed), I was still at +17° BTDC. Not sure if Will's car is retarding the timing, but mine wasn't.
Old Oct 23, 2003 | 08:26 AM
  #115
Is this guy an org member?
http://www.cardomain.com/id/monismo
Old Oct 23, 2003 | 04:35 PM
  #116
WILLSE's Avatar
STUDMAN we gots to talk. PM me when u can or hit me up on AIM talked to stillen and i gots some info.
will
Old Oct 23, 2003 | 05:34 PM
  #117
03BlkSETE's Avatar
This altima guy is alluding to the fact they made some good hp with the hotshot headers. He didn't give the exact numbers yet.
Link
http://www.altimas.net/forum/showthr...hreadid=127935
Old Oct 28, 2003 | 06:31 PM
  #118
03BlkSETE's Avatar
For anyone who care it looks like the Hotshot headers for the Altima made 14 hp and 6 lbs torque over an already fully modified exhaust.
Here's the link
http://www.altimas.net/forum/showthr...hreadid=128556
Old Oct 28, 2003 | 06:35 PM
  #119
OT n00bs FTMFCSL
Mine got stolen last year at the track ****** a$$hats...
Old Nov 17, 2003 | 11:16 AM
  #120
IceY2K1's Avatar
Please post all replies here:
http://forums.maxima.org/showthread.php?t=264127
mkaresh
Mar 12, 2018 06:48 PM
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
Sep 27, 2015 08:37 AM
