My first problem ever @ 31,800mi - Vibration - HELP
This is my first ever problem with my Max. The front end comes under severe vibration around 45mph and especially around 60-70mph. I thought the wheels might need balancing - never had it done before.
So today I had all 4-wheels balanced @ Firestone shop for $50. Well I still have the same problem! Is there something else I should be looking at, or did these jerks NOT do their job right?...
Also, I need to travel 150mi round-trip to NYC tonight & I think I may have to cancel it due to hazard of having my front end fall apart...
What do you guys think could be causing this? Any ideas? I plan on taking it to the dealer... but Sunday serviceshops are very "easy" to find.
G
G
Originally Posted by mad2kmax
does it happen when you are braking or all the time? Like nyc2kmax said, if its when you are braking, its probably your rotors. stock maxima rotors are terrible and tend to go bad rather quickly.
Originally Posted by 02MaXiMa_GLE
No no... not when I'm braking... when I'm riding normally at those speeds.
Is that the same problem you guys are talking about, or was it when you were braking only?
Thanks,
G
Thanks,
G
G
G
G
G
I'm having the same problem but only when I accelerate, the second I let off the gas I'm smooth sailing. I've heard CV Joint, coil, tires, alignment. I'm getting my alignment done on tuesday, if that doesn't help, I'm ripping the engine bay and suspension apart until i find the culprit! haha
my car and steering wheel vibrate when i press my brake pedal... i need front rotors... my dealer wants $140 for clear them and i was like no way... i'll get a new rotors like powerslot with $20-$30 extra... fu*k that yo...
G
G
I would say your wheels were out of balance, but since you had that done...maybe you have a bent rim? I bet most people have a rim that isn't straight/true, but don't know it b/c it's not blatantly visible.
Originally Posted by steelymatt
You were correct in that your wheels need to be balanced. Not a big deal, it's just hard to find someone to do the job right. I went to Goodyear and I didn't have much luck with them. Go to an Infiniti dealership. At least you'll know they're probably doing things correctly. Also, make sure your left and right tires are equal pressure. If after this, they're still vibrating, then you have something wrong with a tire or rim.
If your car is vibrating heavily upon deceleration, have rotors turned (very common amongst us Max owners). I had this done and the car now rides good as new, even makes balancing easier IMO.
If it's vibrating upon acceleration...Check tires thoroughly (rubber could be separating), check motor mounts, joints, bearings.
Hope it helps.
Originally Posted by handsofstone
i'm having the same problem, i hope it's just the rotor's. if its the wheel bearings, how much do they cost to replace?
Courtesy replaced mine for no charge. I purchased the 100,000 mile extended warranty. Hope that it isn't the brakes if your anywhere close to 30,000. I was at 34,000 and Nissan said they wouldn't cover it. I found a local guy that turned all four and put EBC greens on the front for $69.00. Now 13,000 more miles and the judder is back. I think we will all be fighting with the rotors until we go aftermarket. Good luck!
Damn. Thanks everyone. I will check in with the dealership this week. I suspect it was "NOT" balanced properly... bastards! If Nissan charges me for balancing and that solves the problem, then I will get the other guys to refund my $$$ 100%.
G
G
There is an infiniti dealership down the street form my house. i think i will have them balance the wheels for me. i hope that's it.i am waiting for the brakes to get bad before i get some bigger rotors and some EBC's.
Originally Posted by williaa
I got this problem, too(between 60&70 and 90-100). I had my new tire rebalanced and it quit between 90-100 but continued between 60&70.
It's under warranty, right?... Take it to the dealer. They replaced my HUB, AXLE, SPINDLE... all under warranty.
G
Unclejunebug
Apr 2, 2016 05:42 AM
