2001 faster top speed than 2002?
Old Oct 19, 2003 | 10:43 PM
SacMax2002's Avatar
I was at a party last night and I was talking to a guy that had a 2001 SE 5 speed. (Has since totaled it) He claims that although the 3.0 has less HP and Tq, that it has a top speed of 151, which is higher than the 3.5's 142ish. I have taken my car to 142 and it wouldn't give much more. I told him that I didn't buy it. I don't see how a car with that much less HP and Tq can be faster, but I thought I would ask to see if I am wrong. He also claimed something that I disagreed about, but am not for sure. He said that drag is measured by aerodynamics, which I agreed on, but also by the trnsmisission and it bearings. Is that part of the drag measurment on cars?
Old Oct 19, 2003 | 10:46 PM
2k2kev's Avatar
It's chrome alright...
similar top speeds (about 154-ish)
no, mostly it's measured by aerodynamics... They have similar transmissions and I wouldn't be surprised if they used the exact same bearings, so your friend is full of
Old Oct 19, 2003 | 11:48 PM
Y2KSESteve's Avatar
I've gotten mine up to 138 and I still had RPMs left, so who knows.
Old Oct 20, 2003 | 01:05 AM
maseo77's Avatar
i been up to 148 just about maxed out but was at 5000 rpms
Old Oct 20, 2003 | 01:10 AM
GreekMaxima's Avatar
only 130 here
Old Oct 20, 2003 | 02:54 AM
maximilion's Avatar
I got up to about 120 and had lots of room left. Just ran out of road.
Old Oct 20, 2003 | 04:01 AM
1BADMAX's Avatar
Originally Posted by GreekMaxima
only 130 here
I've only done 120mph.....I think.
Old Oct 20, 2003 | 04:42 AM
SEmy2K2go's Avatar
Go BUCKS!!!
I did 158, errr oh wait that was on my Gixxer. My fault.
Old Oct 20, 2003 | 05:21 AM
Blu's Avatar
Blu
the tits
still trying to figure out how you auto guys get above 130
Old Oct 20, 2003 | 05:27 AM
tonylittell's Avatar
WANNA RUN IT?
YA THIS GUY BELIEVES A STOCK CAR CANT RUN 14.1 BUT THINKS THEY HIT 154? SHOOT IVE ONLY GOTTON 135 IN MINE AND IT HAD NO MORE TO GIVE
Old Oct 20, 2003 | 05:38 AM
SR20DEN's Avatar
VQ Wizard
I bet he totaled it trying to catch a 2002 that was outrunning him.
Old Oct 20, 2003 | 05:41 AM
WANNA RUN IT?
Old Oct 20, 2003 | 06:23 AM
Ben's Avatar
Ben
Normally, there are 3 ways a car can be limited on it's top speed:
1. Computer limited.
2. Red line in highest gear.
3. Drag.
Drag can mean anything that generates more friction at a higher speed. This includes wheel bearings, air resistance, transimission, etc. So yes, more than air resistance determines top speed in a drag limited car.
Old Oct 20, 2003 | 06:27 AM
MannyNJ2k2max's Avatar
I was up to 143-145ish in 6thgear with plenty of rpm's left but wouldn't go anywhere- its not whether you have room to redline- its a fuel cut-off after a certain speed
Old Oct 20, 2003 | 06:37 AM
SR20DEN's Avatar
VQ Wizard
There is no known speed limiter on the 6 speed cars. They are drag limited and in most situations the top speed is about 147ish.
Old Oct 20, 2003 | 06:55 AM
2k2kev's Avatar
uhh, lick my what??
http://forums.maxima.org/showthread....=top+speed+gps
Old Oct 20, 2003 | 07:01 AM
BeRTo175's Avatar
I've hit 145 mph and from what i remember i was round 5000 rpms. I def think i could have gone faster but highway began to get a bit bumpy and unstable.
I've heard from many different people that the AE and a few other model maxes havre no governer. That true?
Old Oct 20, 2003 | 07:56 AM
Padsy's Avatar
Boost.....
141 in mine....I had pleanty of gear and redline left. I just ran out of safe road.
Old Oct 20, 2003 | 07:57 AM
Padsy's Avatar
Boost.....
Old Oct 20, 2003 | 10:35 AM
F23A4's Avatar
I ran as fast as 143mph maintaining about one carlength lead on a TL-S on the NJ Turnpike. NOTE: TL-S has a published top speed of 150mph.
Peace.
Old Oct 20, 2003 | 10:46 AM
SR20DEN's Avatar
VQ Wizard
Fifth gear will take the car to it's top speed and it will get there much quicker than sixth. I have had mine over 140 several times and I have yet to find a logical reason to go to sixth.
Old Oct 20, 2003 | 11:06 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
I believe the SE 6spd's are electronically limited to 155. I remember dmbmaxima88 saying something about "bouncing" (limiter) when he had it really pegged.
According to CarTest (power, gearing and drag calculations)
2001 SE 5MT: 144
2002 SE 6MT: 148
2002 SE 4AT: 148
You would probably need some mods or some help (downhill, tailwind, etc) to ever hit the alleged "155 limiter" in the 6MT, which I know Steve had.
Old Oct 20, 2003 | 11:15 AM
Jeff92se's Avatar
I'm needing a caw
You need some serious power to go your top speed in the overdrive gear. Also stock speedos are notoriously inaccurate at those high speeds. Even a 3-5% error will make your 140mph a 145mph run. Add some aftermarket tires of whatever OD and the accuracy goes to hell even more.
Old Oct 20, 2003 | 01:32 PM
subdocmax's Avatar
158 for mine lots of room here in AZ to do that jest do not get stopped doing it
Old Oct 20, 2003 | 01:39 PM
I slapped in 6th around 135mph
Old Oct 20, 2003 | 01:55 PM
Triple8Sol's Avatar
I miss the .org!
I've never gone over 135 b/c of my the speed governor built into myself...the Max feels so UNSTABLE at that speed, even with all my suspension mods!
Old Oct 20, 2003 | 02:23 PM
2k2kev's Avatar
mine was pretty smooth at 135 but I wouldn't have cut the wheel over.
I doubt I'd do it again, either... it isn't worth what happens if you get caught
Old Oct 20, 2003 | 02:38 PM
F23A4's Avatar
ditto on both counts!!
Old Oct 20, 2003 | 02:55 PM
Yeah, That was my only and last time I drove @
those speeds (playing w/ a 540i on I-95 once my car was broken in ~5K miles on the ODO) I havent been over 100 since- I must say the car was stable up to those speeds -but then again it was a straightaway
Old Oct 20, 2003 | 02:59 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
143-145ish here against a LS1 SS Camaro.
It was slightly uphill and took FOREVER once I past 130ish. Plenty of RPM left, just not enough HP to overcome wind resitance.
Old Oct 20, 2003 | 03:00 PM
AKM2k5's Avatar
I had mine to 135 before, but for some reason, my cars is missing 15HP!!!!
Old Oct 20, 2003 | 03:42 PM
Darth Vader's Avatar
You guys are crazy, I don't have the road around here to reach those speeds, so far I have only gone 95.
Old Oct 20, 2003 | 03:46 PM
Ben's Avatar
Ben
Roads? Where we're going we don't need roads!
I hit 100 chasing a new t-bird down an entrance ramp. Couldn't need that much road.
Old Oct 20, 2003 | 03:59 PM
IceY2K1's Avatar
I've held my indicated 92-93mph cruise control maximum for damn near 1hr. on several occasions before I've had to let off.
Plenty of roads here.
Old Oct 20, 2003 | 04:03 PM
SteVTEC's Avatar
Old Oct 20, 2003 | 04:26 PM
.45's Avatar
.45
Originally Posted by IceY2K1
"...Plenty of roads here.
AZ cruisin' is sweet (along with a few other SW, W and Upper MW states). I just returned on the 12th after spending 9 days travelling between Phoenix, Prescott, Sedona, Flagstaff, the canyon, Kingman, Vegas, Bullhead, etc. The whole time I'm ridin' in a Hertz Taurus rental with an out-of-alignment front,left tread (shakin' like a wet dog for 1300+ miles) wishin' I was in my Max. At one point between Flagstaff and the canyon I actually passed an 03' SE. I almost stopped and beat the **** outta the guy just for lettin' that happen.
Old Oct 20, 2003 | 04:54 PM
Darius's Avatar
I hit 130 in my 2k1 but couldnt go any faster... only because my tires weren't rated for anything faster and the car started shaking
Old Oct 20, 2003 | 04:59 PM
MONTE 01&97 SE's Avatar
134 in my 03 auto on the 190 in Plano before I came to a booth, and 143 in the 350 both autos.
Old Oct 20, 2003 | 05:15 PM
† ErV †
cruised for about half and hour at ~124 on the florida turnpike at 2am. could have gone faster but.. i was one of two cars on the road so i felt too vulnerable.
Old Oct 20, 2003 | 06:21 PM
JCW915's Avatar
the highest i've gotten was 139. I have an auto. The nissan service guy tells me that the way the car is designed, it's very hard for it to go pass 150, unless you're going down a huge hill.
