how to achieve 14.0 1/4 mile for n/a 2k 5spd max
Old Oct 23, 2003 | 05:07 PM
purekoryo's Avatar
without doing any major stripping of the car and going forced induction, how could I achieve 14.0 in 1/4 mile?
with the setup below im guessing 14.5 in 1/4 mile?
frankencar intake
whole exhaust system
udp
msd ignition if they make one for our cars
aftermarket chip
Old Oct 23, 2003 | 05:17 PM
Y2KSESteve's Avatar
NA I highly doubt you'd be able to pull a 14 flat, despite the modifications.
Old Oct 23, 2003 | 05:19 PM
Maxpat82's Avatar
14.5 IMO yes it can but 14 flat N/A don't really think so!!
Old Oct 23, 2003 | 05:34 PM
doublea's Avatar
frankencar intake
udp
aftermarket chip
Let say you add Intake, Exhaust, Headers, Crack ECU, cam or engine re-work
then it is definitely possible, time to break the piggy bank.
AA
Old Oct 23, 2003 | 05:35 PM
IgS's Avatar
IgS
frankencar intake
udp
aftermarket chip
get the vq35 and a 6 speed
heh
try removing everything u can out of the car, liek the spare, the seat, go with only 1/4 tank o gas, get some light rims and really good tires...then u might be close.
good luck
Old Oct 23, 2003 | 05:42 PM
bigdo26's Avatar
you'd have a hard time doin that - take LOTS of stuff out of car, toss on every bolt on, get drag slicks, and then you could probly hit 14 flat. slicks would let you launch real fast
Old Oct 23, 2003 | 06:02 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
You'd need every NA mod under the sun including some lightening stuff and probably slicks. I doubt you could pull it off on street tires. 00-01's are not the best 1/4 mile cars. Too heavy and not enough torque.
Old Oct 23, 2003 | 06:11 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Swap in a VQ35 short block with some race gas to handle the 11.3:1 CR and you'll have it.
Old Oct 23, 2003 | 06:12 PM
wantasupra3's Avatar
You would need: intake, all exhaust, suspension, Slicks!!, make the car lighter (take out seats, spare, all trash, carpet, go on a diet) and good track conditions (like 50mph down wind would help) and the you might get a low 14....lol good luck
Old Oct 24, 2003 | 07:10 AM
91 EX-R's Avatar
What does your car run now?
Old Oct 24, 2003 | 07:47 AM
Luquire's Avatar
I say it is very possible with engine work. I do not think the throw of the pistons is different between the VQ35 and the VQ30. this could mean that you could get your engine boared out and blue printed. also a nice port and polish of the heads would be nice. i think with an exhaust system and intake and all this engine work(plus steelies and slicks) you could easily make high 13's. it is all about the engine work.
Old Oct 24, 2003 | 08:30 AM
3.0HO
frankencar intake
udp
aftermarket chip
Get some lighter rims and learn to drive. Launching your car will take some serious practicing and clutch work and gas modulation. Plus you have to shift right at the fuel cut off which takes practice. The 3.0 5th gen are lacking some tq to pull you out of the hole. Once in 2nd just bang the gears at fuel cut off.
If you had an intake - headers - b-pipe and TechSquare chip it might be possible.
PS not too many 2k-2k1 5spds have been to the track. But many have pulled in to the 14's and one as low as 14.3 so it might be possible. Start practicing!
Old Oct 24, 2003 | 09:05 AM
MannyNJ2k2max's Avatar
frankencar intake
udp
aftermarket chip
its your only chance- lots of it!
Old Oct 24, 2003 | 09:27 AM
IceY2K1's Avatar
They have a different bore AND stroke.
Old Oct 24, 2003 | 09:29 AM
nismology's Avatar
Get a 4th gen...
Old Oct 24, 2003 | 09:31 AM
IceY2K1's Avatar
Or an auto 2K2 and let babyblue drive it.
Originally Posted by IwANnAMaX96
Get a 4th gen...
Luquire's Avatar
oh sorry i thought they had the same stroke. still there has to be some way to bore the engine out. what piston could be used? still stand by the port and polish of the heads.
MAXSE5SPD
Aug 23, 2015 12:06 PM
