OBD scanner code
Old Oct 27, 2003 | 08:25 PM
Peter's Avatar
OBD scanner code
Ne one familiar with the OBD code P1320.
Old Oct 27, 2003 | 09:50 PM
jonbth's Avatar
Component Description
IGNITION COIL & POWER TRANSISTOR
The ignition signal from the ECM is sent to and amplified by the power transistor. The power transistor turns
on and off the ignition coil primary circuit. This on-off operation induces the proper high voltage in the coil
secondary circuit.
On Board Diagnosis Logic
Malfunction is detected when the ignition signal in the primary circuit
is not sent to ECM during engine cranking or running.
Possible Cause
I Harness or connectors (The ignition primary circuit is open or
shorted.)
I Power transistor unit built into ignition coil
I Condenser
I Crankshaft position sensor (REF)
I Crankshaft position sensor (REF) circuit
DTC Confirmation Procedure
NOTE:
I If “DTC Confirmation Procedure” has been previously
conducted, always turn ignition switch “OFF” and wait at least
10 seconds before conducting the next test.
I If DTC P1320 is displayed with DTC P0335, P0340, P1335
or P1336, perform trouble diagnosis for DTC P0335,
P0340, P1335 or P1336 first. Refer to EC-391, EC-399,
EC-596 or EC-602.
Old Oct 27, 2003 | 11:00 PM
BigDogJonx's Avatar
Looks like one of the coils has failed or the whole set is dying.
Dixit
Old Oct 28, 2003 | 06:17 AM
Peter's Avatar
thanx
Dixit
Yeah I thought it had somethjing to do with it, but now im sure. Thanks a lot.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
