Anyone else had their HLSD stop working?
Old Oct 28, 2003 | 03:42 PM
Stereodude's Avatar
I got an appointment at the dealer tomorrow to have them take a look at my car for a few things. Probably most notable would be the HLSD not working.
When I first had the car I could tell the HLSD was working. Now I can tell it's not working.
For example, before I could have 1 tire on ice and 1 tire on pavement. From a stop the car would still accelerate normally. Now, with one tire on pavement and one tire on wet grass I just spin the wheel on the grass and move forward slowly
Anyone else noticed this?
Old Oct 28, 2003 | 03:50 PM
maximadave's Avatar
detailerdaveb@gmail.com
do you have a 6-speed or auto?
Old Oct 28, 2003 | 03:54 PM
IgS's Avatar
IgS
the car has HLSD if its a 2k2+ 6 speed and has the AE pedals right?
Old Oct 28, 2003 | 03:55 PM
psychlone's Avatar
The HLSD only comes with 6 speed equipped cars. Automatic Cars get Traction Control. Unfortunately, my 6 speed does not have HLSD so I can't really help you in that regard.
Old Oct 28, 2003 | 04:00 PM
maximadave's Avatar
right! Just curious if Stereodude knows if he has HLSD or not.
Old Oct 28, 2003 | 04:49 PM
Stereodude's Avatar
It does (2k2 6speed w/ AE pedals). I ordered it with it and I was able to verfy it on many occasions while driving. Now, in those same occasions it behaves like it doesn't have one.
Old Oct 29, 2003 | 10:38 AM
Stereodude's Avatar
Well... The cars at the dealer today. We'll see what they say.
Old Oct 29, 2003 | 10:46 AM
SR20DEN's Avatar
VQ Wizard
I think mine sometimes has a slower response time than is did but I have no proof. But it never completely stopped working.
Old Oct 29, 2003 | 02:29 PM
hct67's Avatar
HLSD? How Do You Know?
Is there a way to check out of your Maxima has the HLSD? I brought a 2003 Maxima SE 6 Speed and I am not sure if it does or not? is there a websight that you can punch in your VIN# and see? Also How do you find out if you have heated mirrors. The manual they gave me was just a basic manual!! If this helps I also have power seats(both) Heated Seats (both) Heated Steering Wheel.
Old Oct 29, 2003 | 02:31 PM
Stereodude's Avatar
The dealer says they can't verify/duplicate the problem. I still think that it's not working right/broken. I can spin the outside wheel in a corner when I couldn't before.
Anyone know how hard it is to open up the tranny and have a look?
Old Oct 29, 2003 | 03:04 PM
Newman's Avatar
does anyone know a 100%, officially varified way to test if your car has HLSD/if your HLSD is working?
the "jack up the car and spin the tire" technique seems to be just speculation. does anyone know for sure?
Old Oct 29, 2003 | 03:46 PM
HondaKilLR's Avatar
Rev it up to 6.5k and drop the clutch? Does it leave two tire marks(working), or one(not working)?
Old Oct 29, 2003 | 06:02 PM
Stereodude's Avatar
My dad and I are trying to come up with a definitive test. I'm wondering about a Dyno where the dyno bolts to the wheels on each side rather than a drum. If they can increase the rolling resistance on one side a lot they should be able to tell (I'd think). Problem is I need a fully functional HLSD car to prove that mine is abnormal.
Old Oct 29, 2003 | 06:10 PM
SR20DEN's Avatar
VQ Wizard
When can the dealer ever duplicate the problem? That's pretty funny because the only way they can do it is to peg leg around a corner like you do.
Old Oct 29, 2003 | 06:11 PM
SR20DEN's Avatar
VQ Wizard
That does not apply to a helical unit. It only works with torque applied to the ring gear. Up on a lift it behaves just like an open diff.
Old Oct 30, 2003 | 03:02 AM
MrGone's Avatar
try spinning it the tires faster, they are designed to have some slip in them, otherwise it you would break loose on every turn you make. It might also need to be adjusted, but I dont completely know the difference between the HLSD and VLSD's.
Old Oct 30, 2003 | 05:13 AM
sorcereur's Avatar
Stereodude, I have HLSD and have verified it in many instances.
If I put one tire on grass/gravel and one on pavement and floor it, the tire on the pavement will start pulling actually to the point where u get wheel hop ONLY from THAT tire on the pavement. Mine does that all day. That's the for sure way of checking it. In a corner, you can also tell. Just point the wheel and floor it in a low gear. When LSD kicks in, u can practically let go of the wheel because it's going to stay in the direction it's pointing until the other tire gets traction back. It kicks in so fast that the tire that's on gravel or whatever never even starts to spin.
HCT67, check and see if you have drilled aluminum pedals. If you do, then you probably have LSD. Then, do the above i mentionned and you'll be able to tell. If u don't have the pedals, u don't have LSD. Only two ways to get HLSD as an option; basically as the only option after the sunroof, or once the car is fully loaded with every option available except nav. Basically if u starts adding options after the sunroof, HLSD doesn't become available again until loaded. When i was looking for mine, i was looking for HLSD, and that's what i found out.
Hope this helps.
Old Oct 30, 2003 | 06:35 AM
Stereodude's Avatar
Hope this helps.
Sorcereur, I've also verified mine in many instances. That how I know it's not working anymore. It doesn't behave and drive like it used to. I did the tire on the grass/dirt test the other day, and I was able to spin the tire on the grass and not really move.
SR20DEN and myself discussed a few ways of testing it where it can be proven to the dealer. My current plan is to test my car and video tape the results showing one wheel spinning with the other wheel on a tractive surface while the car sits still. Of course I will need footage of another HLSD equipped car moving forward without wheelspin in the same situation. Otherwise the dealer will claim that the behavior I'm seeing is normal.
Hopefully I can get mine taped this weekend. Then I need to find another HLSD car in my area that I can repeat the test on. I think finding another one by me will be my problem.
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
kenc15
Aug 5, 2015 08:29 AM
