let's have a dicussion about MAF
Old Nov 24, 2003 | 09:03 AM
BioMaxDDS's Avatar
I can't search.........
What is the deal with MassAirFLow sensor?
At first, people were saying its because when we clean the K&N filter, the oil got to the sensor, and that's the cause for it to malfunction
Then, there was a TSB out to update our computer. That didn't work
So, what is the deal?
Is there any reason why it keeps on failing?
I'm going on my 4th MassAirFlow sensor....
I didn't clean my K&N filter (i bought a new one instead), that didn't work
I went and did the TSB, that didn't work
I went ahead with 2k1 MAF, that didn't work
so what should I do next, I know I'm going back to stock intake
but what about the people with aftermarket intake?
Does Nissan purposely made a weak MAF, so that they can make mad lots of profit from it?
Old Nov 24, 2003 | 09:08 AM
Ryanb126's Avatar
I just recently installed a PR CAI and I had already blown my maf before. I bought a spare one for $88 the other day just in case it blows again and i'm keeping it in the trunk. Don't want to get stranded at the track
Old Nov 24, 2003 | 09:11 AM
DJSCIASCIA's Avatar
Do u think vibration could be the cause to the failures if its not the oil???
Old Nov 24, 2003 | 09:14 AM
BioMaxDDS's Avatar
I don't know that much about cars...so I really don't know
but I can tell you the last 2 times that my MAF went out is during full throttle
which brings me to another point....what's the point of having a fast car....
if when I go full throttle there is a chance of MAF going bye bye???
Old Nov 24, 2003 | 09:16 AM
Tac_M's Avatar
They SUCK!!! I’ve blown one on my 2k1 with a K$N filter drop-in and since then I’ve been using the OEM paper filter with no problems. But now I have a 2k3 and I’m looking to get the frankencar intake and exhaust. I hope that apexi filter will be gentle enough for my POS MAF.....
Old Nov 24, 2003 | 09:50 AM
Hamy's Avatar
How much does it cost to replace the MAF? Will Nissan warrenty it once I get above 36k in a few months?
Old Nov 24, 2003 | 09:54 AM
dansmax2003's Avatar
How bad is it?
So, now i'm really curious, does everyone here had a problem with their MAF sensor already? Sounds like it is a very very comon problem and it scares me. I didn't know that it was such a big issue with Maximas before i got my car.
Are there any people who have more than 40k miles on their Max and still keep their original MAF sensor?
I have a 2003 Max with 26k miles, all stock, and after reading all this, i'm wondering how can i avoid this problem. Sounds like keeping my stock intake and stock filter is the best "solution"....or that doesn't help either? what do you think?
Also, if the MAF fails, is the car driveable (even sluggish) or i'll need a tow truck? I don't want to have a new car and sit on the side of the freeway.
Old Nov 24, 2003 | 10:37 AM
MacAlert's Avatar
I had my Frankencar on for like 1000 miles and no problem here. Maybe you should try the new MAF, i think the last four numbers are 6800 or something like that.
Old Nov 24, 2003 | 10:42 AM
K1maxima02's Avatar
I have a original MAF sensor and have it almost 40k (38Kmiles). I have a injen intake for about more than 10 months. I still have no problem on cleaning my filter and putting back or anything like that. But still it scares me watching other 2000-2003 max MAF fu*cked.
Old Nov 24, 2003 | 10:51 AM
fishhouse's Avatar
i have a 2k with 46k miles. K&N filter and OSCAI custom air intake for the last 10k miles or so. no problems to date (knock on wood)!
Mick Max's Avatar
Wild at Hurt
How much do MAF's cost by the way ($88 like posted above?)
I put 85K (50k with k&n) and now 20K on my 03 (15K w/ PR CAI)
and no problems.
Old Nov 24, 2003 | 11:12 AM
spirilis's Avatar
K&N drop in panel filter... no MAF problems after 10K miles
I did spray the MAF wire (it was a wire, didn't look like a piece of film) with Air Intake & Throttle Body cleaner once... no problems (also cleaned the throttle body at the same time)
I would imagine excessive vibration could cause a failure, especially if the MAF is as delicate as we're lead to believe.
Old Nov 24, 2003 | 11:18 AM
Mick Max's Avatar
Wild at Hurt
Vibration might not be so far fetched. Like an e or b string on a guitar if it vibrates too hard it can break. And modified intakes create a "musical' moan or howl with a lot of harmonics.
Old Nov 24, 2003 | 11:32 AM
emax02's Avatar
From my experience (I have blown 5 or 6 MAFS in the last few years) I would stay away from Superchrges and Apexi Filters. It seems the turbulance caused by these two may make the film in the MAFS to cold and thus making it fry. This is just my hunch... K&N filters when oiled correctly seem to kill the MAFS every 20K miles.
Old Nov 24, 2003 | 11:34 AM
Sam03's Avatar
Hmmm, (knocking very loudly on wood) two re-oils now on my Frankencar with K&N and at 20k miles, and not a problem yet.
Old Nov 24, 2003 | 12:02 PM
BioMaxDDS's Avatar
so I guess I won't be able to avoid changing it unless i go back to stock?
lol
Old Nov 24, 2003 | 12:08 PM
emax02's Avatar
lol
Basicly and even then your probably screwed, lol.
Old Nov 24, 2003 | 12:11 PM
spirilis's Avatar
Also consider, a lot of aftermarket intakes are made of metal right...?
Perhaps the metal construction transmits more vibration (from the chassis/engine/whatever) than the OEM plastic intake piping...
The stock plastic intake piping has an accordion tube between the throttle body and MAF/resonator, then the airbox has some rubber washers/gaskets in the mounting brackets...
I saw a 4th gen Injen, and the lower tube is bound by a metal arm welded to the tube which fits into an existing bolt/bracket on the engine (think it's an EGR or coolant tube bracket)... no rubber cushioning, just metal-on-metal contact. If other intakes do it similarly, it's no wonder the MAF experiences vibration.
Old Nov 24, 2003 | 12:15 PM
Padsy's Avatar
Boost.....
Hey ole buddy.
Old Nov 24, 2003 | 12:16 PM
emax02's Avatar
Originally Posted by Padsy
Hey ole buddy.
Whats up bro You know I still have not had a single smoke
Old Nov 24, 2003 | 12:23 PM
Padsy's Avatar
Boost.....
SWEeeeeeeeeeeeet Keep it up.
BTW...check out the new wheels....SSR's
Old Nov 24, 2003 | 12:24 PM
Padsy's Avatar
Boost.....
Oh yeah....i have center caps now....they came in
Old Nov 24, 2003 | 12:26 PM
BioMaxDDS's Avatar
Does anyone know if other VQ3.5 are failing too?
the ones w/aftermarket intake
Old Nov 24, 2003 | 12:31 PM
Padsy's Avatar
Boost.....
Not as many as ours.....Mine died with the Frank-n-take.
I think it was the vibration of wheel hop....under full throttle.
I have GAB now with K&N panel. No problems...but I think i need to spray some cleaner on it...just to be safe.
Old Nov 24, 2003 | 04:28 PM
sascuderi's Avatar
I really think that is it and have posted my theory before. Many have lost their MAFs during WOT. I bet the MAF just can't take the increase in voltage during WOT and after repeated WOT they just go. Many have lost their MAFs on this board because they are aggressive drivers with frequent WOT.
So...to protect your MAF you need to drive like grandpa and never, never press the gas more than 1/3 of the way.
Old Nov 24, 2003 | 04:55 PM
Mick Max's Avatar
Wild at Hurt
Howwww muchhhh areee theyyyy. Is it the $88
Old Nov 24, 2003 | 04:57 PM
BioMaxDDS's Avatar
ya around that price
do you guys think there might be an aftermarket for our MAF?
Old Nov 24, 2003 | 05:00 PM
IgS's Avatar
IgS
im also interested in this, how does a car with a failed MAF behave????
-IgS
Old Nov 24, 2003 | 05:08 PM
WILLSE's Avatar
LOL! 88 was a used price i think. for the entire unit i think its around 400 bucks. just for the sensor part its within 110-200 i think. sry im not exact but it gives u the idea.
will
Old Nov 24, 2003 | 05:10 PM
WILLSE's Avatar
-IgS
wont rev past 2500rpms.
will
Old Nov 24, 2003 | 05:30 PM
IgS's Avatar
IgS
will
so it would be possible to go for 40 miles at a slow speed with a blown MAF right?
Old Nov 24, 2003 | 05:39 PM
Hamy's Avatar
Could anyone answer my question about warrenty coverage? You guys cant tell me your putting out $200+ every time this thing goes out!?
Old Nov 24, 2003 | 06:25 PM
BioMaxDDS's Avatar
if you have aftermarket intake, the dealer will MOST likely not replacing it under warranty.....
Its around 90-100 for a new one (just the sensor)
yes, I have spent $200.00 already on these sensors...
and today I just spent about another 200 for 2 new ones
Old Nov 24, 2003 | 06:32 PM
Mick Max's Avatar
Wild at Hurt
Thanks WillSE,
Was thinking of carrying a spare one, but not at $400. While we are on the subject, by sensor, you mean the wire type element right? Anybody know what is involved in changing the sensor.
Hey, I gotta learn something new every day or it does not feel right.
Old Nov 24, 2003 | 07:18 PM
irish44j's Avatar
retired moderator
I am interested in knowing this also....btw, anyone have the part # for the SENSOR for a 2k?
Old Nov 25, 2003 | 05:00 AM
fishhouse's Avatar
a dealer will NOT cover a blown MAF once you are out of your 3 year/36k mile warranty. and they would likely even not cover it if you are in warranty but have an intake.
Old Nov 25, 2003 | 12:02 PM
frankieduxAE's Avatar
i blew my maf at 34k miles. i still have my stillen/k&n intake but have the stock air box on right now. i miss the intake badly, but i'm afraid the MAF will blow again once i reinstall the k&n. damn nissan and their weak **** MAF's.
what's the name/brand of that throttle body cleaner that you guys are using?
thanks
-frank
Old Nov 25, 2003 | 12:04 PM
i had to install my stock air box before taking it into nissan to get the MAF warrenteed. They also flashed my ECU, is that necessary??
- frank
Old Nov 25, 2003 | 12:14 PM
spirilis's Avatar
- frank
probably, especially if they installed an updated MAF sensor that's more reliable (and has different output parameters to the old one...)
Old Nov 25, 2003 | 01:01 PM
Ryanb126's Avatar
will
The original MAF price when i blew mine a year ago was around $400. I just recently installed a new PR CAI so i went to the dealer and talked to the parts guy who i'm friendly with and also gives me a discount since i'm in Houston Nissan Enthusiasts (houston nissan club). I asked him just for grins how much a new MAF would be in case i blew this one, and he stated it would probably be around $400 but he looked it up in the computer anyways. His draw dropped when he saw it was listed at around $105 I think. Evidently, the part number on them has been changed implying that a there is a new MAF out, and it's only $105 now. With the discount it was 88 for me so I went and bought one to keep in the trunk just in case I blew mine at the track or something. ****es me off that nissan took my $400 a year ago though
