spring pop, n pull
Old Nov 24, 2003 | 12:16 PM
ColdSHO's Avatar
spring pop, n pull
i recently had a set of maxspeeds put in inplace of my stockers, still on stock struts. when i first drive the car the front end makes a low rubbing sound and sometimes a pop and then my alignment is thrown off so bad i can barely drive the thing, depending on the turns u take, sometimes itll pop back into alignment and sometimes not, usually not, mainly pulls to the right. i had an alignment done but it didnt do anything. any ideas?
Old Nov 24, 2003 | 04:58 PM
Maxpat82's Avatar
It's look like the lower struts bolt aren't thigh enough!!
Else I don't have any idea!!
If you have it aligned, I don't know what to tell you!!
Old Nov 24, 2003 | 05:02 PM
92 SE-R 02 SE
were the upper strut mounts installed right? there is an arrow that faces outward, and if it not right, that could be the problem. Was it a good shop that did it? Maybe the spring isnt seated correctly (i had that prob on my sentra) and everytime i turned, the spring would "bounce"
There are only 5 bolts also, make sure they are all tight. 2 on the struts, and 3 up top in the engine bay. Oh, and the 1 on the strut as well.
Unclejunebug
Apr 2, 2016 05:42 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
followthadollar
Sep 27, 2015 01:06 PM
