Check Engine Light
Old Dec 6, 2003 | 06:22 PM
RHD MAX's Avatar
Check Engine Light
I realize this is probably one here somewhere but since i cant search i will just ask. I reset the ECU on my 2000 SE and did a little throttle body cleaning today, put everything back together, took her for a spin, and on my way home the Light came on. I put all vaccum lines back on. Is there a way to check the ECU for fault codes on 5th gens like there is on previous maximias? if there is i would be greatful to anyone that pointed me in that direction. Thanks
Old Dec 6, 2003 | 11:36 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
you will have to pull the code(s) with a obd2 diagnostic tester. there is no led light to read in order to get the codes like on 4th gens. best bet is autozone since they perform it for it no charge.
Old Dec 7, 2003 | 03:52 AM
BigDogJonx's Avatar
Autozone is the only place. Advance Auto does do it, neither does PepBoys. Unless you got a fellow buddie who has an OBDII scanner like I do.
Dixit
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
