my maxima would NOT idle or run longer the 5 sec
Old Dec 8, 2003 | 08:49 PM
shospecialist's Avatar
hello, i have a 2001 nisan max AT, that i bought about 2 months ago wrecked. after two months of body work i finaly got my car back.Car had a real hard time starting and had ses light on, so i checked for codes and found that it has bad CPS. during the wreck the sensor and and the plug got damaged so i ordered new CPS sensor and found a plug for cps on the junk yard form a 92 maxima it looks just like the original one on 2001. so i cut the wires and instaled new sensor and the plug and car fired up like new no problems starting.I took the car to local shop for a interior detail and they somehow managed to use all the gas in the car, i mean they gave me car back running on fumes. so i took the car to gas staion filed it up half full and headed back home. On the way back home i got on it prety hard to se how fast it is and it pulled realy hard, then i slowed down and maybe half a mile later my car just died on me. towed it bak home checked for codes and it showed cps being bad.But i never reseted the ECU after i installed new one. so i took the batery cables of for maybe 5 min then put them back on and now car starts up and runs for maybe 5 sec then dies. so far i tried unpluging the cps to se what happens and all it does it makes my car start litle bit harder then dies again after 5 sec. i tried cleaning the maf didnt do any good i took the fuel pump out to see if it dirty or cloged up and i couldnt get it out of white box, but you can hear it run just fine, also when i start the car and give it some throtle then it dies instantly or revs for sec and dies very quick and sometimes you can hear poping noise like its back firing or something.Does anyone have idea what the problem, or solution is to fix my car. or just any onfo what to do next? thnx for all the help and sorry for the poor vocab.
ben
Old Dec 8, 2003 | 09:14 PM
jmd102's Avatar
Anti theft / Immobilizer may do the same thing? I know in alot of domestics, fuel is shut down but will initially start and then immediately die. Just a thought. I'm not up to speed on Max anti theft but maybe something to verify and check....ya just never know! Other guys here hopefully can give you additional insight with their personal experiences.
Goodluck.
Mark
Old Dec 8, 2003 | 09:28 PM
i dont think its any theft device since it happened while driving and i have original key.
Old Dec 8, 2003 | 09:39 PM
maximatt's Avatar
a new car......
Maxxxed's Avatar
tEh Hope
"I took the car to local shop for a interior detail and they somehow managed to use all the gas in the car, i mean they gave me car back running on fumes."
I am still trying to understand that statement. Why would a detail shop drive around in your car? They prolly fu<ked your car up after a few joy rides and doughnuts...
Old Dec 8, 2003 | 11:14 PM
Its not new but its my new car and yeah they probably ****ed something up, but i still need to fix it anyone has any ideas what could it be???????/
Old Dec 8, 2003 | 11:21 PM
FanaticMadMax's Avatar
Wow, sorry to hear that. I don't know what possible cause. Why don't you take it back to the body shop where you had it fix, cuz they must have done somethign to it, they are liable for the work they done. How good is their work gurantee for?
Old Dec 9, 2003 | 04:07 AM
ToYLeT902's Avatar
JET Speed Lab
Even though you said you cleaned your MAF, i'd say you need a new one. MAF senors are very sensitive, So just look into that.
Old Dec 10, 2003 | 09:50 PM
car is at a mechanic shop now being fixed . il let you all know what was wrong with it as soon as they let me know.
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
Finkle
Sep 27, 2015 09:53 PM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 13, 2015 12:50 AM
