Symptoms of a broken engine mount?
Old Dec 10, 2003 | 06:31 AM
MattBeaty's Avatar
I have seen a few posts about people with broken engine mounts, but I would like to know what the symptoms of them are. I have a 5sp Y2k and when the tires should be spinning, the car is very jerky and makes a clunking noise. Could this be a broken engine mount?
Thanks for your help
Old Dec 10, 2003 | 06:48 AM
spirilis's Avatar
That's a good question
I can almost never get my tires to squeal under dry road conditions... not even in 1st gear, but I CAN induce gobloads of repeated wheel hop.
Old Dec 10, 2003 | 08:01 AM
MattBeaty's Avatar
Spirilis: It sounds like you are experiencing the exact same thing I am. I can hear the tires squeakk a little, but I mostly get wheel hop.
Old Dec 10, 2003 | 08:06 AM
spirilis's Avatar
I did get to smoke my front tires the other day though... spinning on snow, snow turned into blacktop, wheels kept spinning... I laid off the throttle when I noticed some white smoking coming up from the front-end
Old Dec 11, 2003 | 01:52 PM
twiggy144's Avatar
tires dont have to spin to hear the noise of a broken engine mount. Shifting from P or N to R or D , may cause a broken engine mount to clunk. Also, shift in D or R , press firmly on the brake, and rev the engine a bit, and listen for the clunk noise.
Old Dec 11, 2003 | 05:59 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
Actually, it's really easy to see if you have a broken motor mount. All you need is a friend to help you out.
Start the car and open the hood.
Have your friend press on the gas pedal and hit 5K rpm.
If a mount is broken, the engine will literally look like it is trying to jump out of your engine bay. Whichever mount that's broken will be the area of the motor that "jumps" the highest...
And if your engine just torques a little to one side, it's not broken. You'll definitely know if it's broken when you step on the gas...
Old Dec 11, 2003 | 09:02 PM
Audtatious's Avatar
Bandwagon Lover
What about tranny mounts....Same thing?
Old Dec 11, 2003 | 09:25 PM
Ghase's Avatar
I too think my mounts are broken.!!!!!!! But which one, engine or the tranny.??????
The sound on my car is more a bump kind of sound and not a clunk. I only hear it when I spin the tires.!!!!!!!!!!!!!! This is crazy.
Old Dec 12, 2003 | 08:03 AM
MattBeaty's Avatar
Thanks for the good information. If one of the motor mounts is broken, are there replacements that are stronger, or will I have to buy an original part?
Old Dec 12, 2003 | 09:06 AM
OT n00bs FTMFCSL
You can use the Place Racing mounts...with a little work, that is...
wyobbagy
Jan 3, 2023 12:03 PM
Violator
Sep 9, 2015 10:14 AM
Hdnseek
Sep 9, 2015 05:55 AM
