Wind Noise from passenger side rear???
Old Dec 22, 2003 | 12:33 PM
skandalouz's Avatar
i've had this pretty bad wind noise from the back window on the passenger side for the past couple of days now... almost like the window is open a little bit (it's that bad)... and it started suddenly out of nowhere... i've read about lots of people who have had wind noise problems... is this what typically happens with u guys too? or is something wrong with my door/window??? i've opened the door and windows several times and closed it back up.... nothing is caught in there that i can see.. but when i drive at medium speed and up, the noise is pretty noticeable.... will the wind noise tsb help?
Old Dec 22, 2003 | 12:34 PM
asu174's Avatar
Clay Aiken has fancy genitals
I have the EXACT same problem. Anything over 50 mph and it is irritating.
Old Dec 22, 2003 | 12:38 PM
skandalouz's Avatar
have u done anything to fix the problem?? i can't figure out what's wrong with it... it's not like i've done anything to make it do that so suddenly...
Old Dec 22, 2003 | 01:00 PM
OutMaxxed's Avatar
i think this problem occurs on all 5th gen max's.. mine also has wind noise..except its on both rear sides. I guess Nissan overlooked that area
Old Dec 22, 2003 | 01:04 PM
Mkang513's Avatar
TSB did the trick for me.
Old Dec 22, 2003 | 01:07 PM
jattmax's Avatar
my max has the same, the rear passenger side is extremely annoying, does sound like a window is open... once again, too lazy to take it in to dealer...
Old Dec 22, 2003 | 01:13 PM
sweeper's Avatar
Here is the link: http://www.atalla.net/maxima/WindNoiseTSB.pdf
There's a sticky posted with lots of the TSB's and this one is in that list. I have my car in the shop today for right rear wind noise and some other stuff. The advisor said they keep repair kits on hand and it's no charge.
Old Dec 22, 2003 | 02:00 PM
MONTE 01&97 SE's Avatar
Mine does sometimes, it seem that its mainly the 02/03's. I know something isnt right because that window gets that foggy/misty stuff on it sometimes.
Old Dec 22, 2003 | 04:46 PM
Cdriven's Avatar
My Max has the same wind noise from the rear passenger side door. What I don't understand is why it didn't make this noise when I first bought the car. Suddenly, one day, the wind noise started. Anyway, I'm assuming the dealership can fix it.
Old Dec 22, 2003 | 07:27 PM
SEmy2K2go's Avatar
Go BUCKS!!!
[QUOTE=sweeper]
There's a sticky posted with lots of the TSB's and this one is in that list.[QUOTE]
http://forums.maxima.org/showthread.php?t=29351
Most of you guys have been on here long enough to have heard something about this issue. Check out the TSB's and quit being lazy and just take your car in and have the dealership fix it. I had the same issue, made an appointment with the dealer, and it's 100% fixed. Just do something about it already.
Old Dec 22, 2003 | 07:59 PM
trey
My dealer said the tsb didn't fix it, so i guess i'm stuck with this noise. gotta find some kinda solution for this.
Old Dec 24, 2003 | 06:39 PM
asu174's Avatar
After looking over the TSB, I am going to just order 2 of part # 80339-2W100 from DaveB because.....
1. I can fix this myself.
2. I can't be without my car.
3. I don't trust dealers with my car.
At this point, when my MAF finally goes, I would rather pay $80 for a new one from DaveB then have to mess with taking it in. I will do anything to avoid dealer visits.
Old Dec 24, 2003 | 06:45 PM
bigdo26's Avatar
What is the part that needs replacing? Maybe I'll just do my own fix on that too, since the dealer is a pain to work with
Old Dec 24, 2003 | 08:01 PM
KCMichaelM's Avatar
Basically it is just additional "sealant" around the window. It is a type of foam tape you put behind the weatherstrip to make a tighter seal to the window glass.
Old Dec 24, 2003 | 08:04 PM
asu174's Avatar
See sweeper's post with the TSB link. All they do is add some foam in on the weatherstripping. The part number is 80339-2W100 and you should order two. My guess is that the entire transaction will cost around $5.
Old Dec 24, 2003 | 08:08 PM
bigdo26's Avatar
Thats what I figured. Strange that its only one door that does that tho... So couldnt I grab some weather stripping from Home Depot and do it?
Old Dec 24, 2003 | 08:13 PM
KCMichaelM's Avatar
Give it a while... it won't be only one door
Old Dec 24, 2003 | 08:19 PM
bigdo26's Avatar
Thats probly all too true
Old Dec 25, 2003 | 01:39 AM
HNDA ETR's Avatar
Still Here... IM me for more..
doesn't the TSB run out once you hit 3 years/36K miles?
Old Dec 25, 2003 | 06:34 AM
asu174's Avatar
Well, your warranty does, so yes.
Old Dec 27, 2003 | 07:40 AM
fibersplicer's Avatar
I have a 2002 and it has really bad wind noise. I have taken it in three times to differant dealers and they can't seem to fix it. What ever the so called fix is does not work. I just learned to live with it. I just turn up the music and drowned it out. That is the only fix that works for me.
Old Dec 27, 2003 | 07:48 AM
caremd99's Avatar
I bought weather stripping at Home Depot last year and did all four doors. No more wind noise.
Old Dec 27, 2003 | 07:15 PM
NYC TAR's Avatar
How do I take out the rubber striping? Do I just pull out it with pliers or dig in with my finger nails and pull out. or Do I pull out the the chrome molding? after it is out, do I just push it back in. I just don't want to rip the striping . thanks need help!
Old Dec 28, 2003 | 08:30 AM
No the TSB did not work for me. I had it done three times at differant dealers. I think they just replace the rubber around the small window in the back.I think the wind noise must be coming from some other place, I gave up trying to fix that one.
Old Dec 28, 2003 | 08:35 AM
[QUOTE=SEmy2K2go][QUOTE=sweeper]
THE TSB DOES NOT WORK. Taking it to the dealer is a waste of time. I did this three times I know.
Old Dec 28, 2003 | 11:16 AM
jeepik's Avatar
ok i just went out....mine started making noise again...last time i fixed it i used vynil foam tape....the problem with that type(same as they use with the TSB) is after time it deforms, now i used poly foam tape. this stuff doesnt deform..we'll see how it will hold up...i'll drive it this evening and report back tomorow if the wind noise has gone away
Starrider
Sep 17, 2015 07:26 AM
lux97Max
Sep 14, 2015 03:54 PM
jhontelj
Aug 17, 2015 04:07 AM
RealityCheck
Aug 5, 2015 06:18 AM
