camber adjustment
Old Jan 17, 2004 | 02:02 PM
nmaxima_24's Avatar
camber adjustment
can the rear wheel negative camber be adjusted or its a factory thing?
Old Jan 17, 2004 | 02:45 PM
bsetiawan's Avatar
The rear camber and toe setting is fixed. It cannot be adjusted at all.
Old Jan 17, 2004 | 02:55 PM
nmaxima_24's Avatar
I've seen some maximas (2001 SE) with 0 camber, why?
Old Jan 17, 2004 | 03:54 PM
Mick Max's Avatar
Wild at Hurt
A lot of ***** and a torch? That would be my only guess.
Old Jan 17, 2004 | 04:06 PM
bluemaxx's Avatar
Moderator GT-R
I think you would do it with a bigass press but it isn't en exact science. I read about it here though.
You could also cut a slot on each side of center of the beam; through the top, front and back of the beam. Bend the beam up on each end to close the gaps and weld it back together. I'd want to build a jig for this because you could get some undesirable results if not very careful.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
