I need progress RSB How-to. It is not in the How-to section
Old Jan 22, 2004 | 09:34 AM
Luquire's Avatar
I need the instructions on how to install the progress cattman RSB. I am afraid that i will mess the brake line up if i dont install it correctly
Old Jan 22, 2004 | 09:36 AM
MacAlert's Avatar
I didnt have to fiddle with any of the brake lines. All we did was bend the E-brake cable bracket a little.
Old Jan 22, 2004 | 09:59 AM
Luquire's Avatar
so is it pretty self explainatory on how to install it
Old Jan 22, 2004 | 10:15 AM
soundmike's Avatar
Very sound, Mike
Pretty much. My word of advice is to loosely attach the beam portion first (it makes the installation much easier).
If the Progress is a 100% replica of the Addco, there should be no need to remove brake lines, bend anything or remove the wheels.
LMK if you need some help.
Old Jan 22, 2004 | 10:26 AM
01SE02SER's Avatar
Faster than a speeding bullet...
If someone has access to the Search feature of the .ORG, look for installation instructions from olincoles.
I used his instructions in addition to what was provided by Progress to do everything.
I'll see if I can put together some write-up also this weekend.
Peace.
Old Jan 22, 2004 | 10:47 AM
Luquire's Avatar
thanks soundmike and 01se02ser but i think i found a how to in the 4th gen forum that will work
Old Jan 22, 2004 | 11:11 AM
soundmike's Avatar
Very sound, Mike
In case you need it, here's from from Matt
http://audtatious.win.net/audio/tech/addcorsb.html
Old Jan 22, 2004 | 11:46 AM
MacAlert's Avatar
The progress sway bar does NOT come with 4 U bolts. I got a bracket to install which is why I had to bend the bracket a little.
Old Jan 22, 2004 | 12:28 PM
Luquire's Avatar
Well ****...i hope it is self explanatory or i am fonged.
Old Jan 22, 2004 | 04:01 PM
sweeper's Avatar
Here's the other link that Soundmike (i think) posted in another thread: https://maxima.org/shoptalk/sub_modi...sb/index.shtml
It's an addco install too, but the only diff in the kit is the side mounting brackets.
You should have no problems. I'm gonna do my Progress bar this weekend and will document it with pics too, in case you want specific Progress pics. I may even do it tonight.
Old Jan 23, 2004 | 05:54 PM
Triple8Sol's Avatar
I miss the .org!
I've had the Addco, and now have the Progress. For some reason I didn't have to mess w/my brakeline?
Old Jan 23, 2004 | 06:15 PM
redstradic's Avatar
i had to remove the brackets for my ABS and zip tie the line to the E-brake line. then i had to bend the E-brake bracket just a tad to fit the RSB bracket on.
Old Jan 23, 2004 | 07:57 PM
808MAX-SPEC's Avatar
Didn't have this bookmarked at work, but here you go. Everyone is gonna want to bookmark this. http://forums.maxima.org/showthread.php?threadid=189641
thatcollegestudent
18
Oct 5, 2015 02:29 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Stagnet04
Sep 13, 2015 09:32 PM
