anyone help me on this?
Airbag light bllinking...Possible problems/solutions?"
i recently had an amp and subs installed by a friend of mine who runs a buisness installing car audio. anyway, after he installed them and i was on the way home, the air bag light beside the blinkers in the dash started blinking. wasnt sure to post this here or not, but anyone with an idea please help.
Well
If you disconnect ANY yellow connectors with the power (i.e. battery still hooked up) it will set this off. There is a specific procedure to clear this if you can find a member with search status to look it up for you. Also check the FAQS...it might be in there.
EDIT: Post #92 Airbag Linky
He should not have been working on your car with battery power applied, but this is my guess on what he did.
Also, in your subject line...make a quick blurb as to what the question is....get a better hit rate.
"Airbag light bllinking...Possible problems/solutions?"
Good luck!
Good luck!
