Those with Navigation....
Old Feb 14, 2004 | 12:30 PM
KLOOGY's Avatar
L33t BMW Drivah
I know I have asked this before, but I will again. Has anyone with Navigation switched out your stock radio ? If so, did you retain all the functions of the Navigation setup with the new deck, single cd player from screen, navi sounds..etc ?.....I need to upgrade my deck, and Im just asking....
Old Feb 14, 2004 | 02:27 PM
Cubanato's Avatar
Joo wanna play??......ok we go to war
there has to be a way that if u get an aftermarket TV u can splice the video input which will go into the stock screen into a video cable and get it to plug into the video input on the new deck
is that what you mean?
-J
Old Feb 14, 2004 | 04:11 PM
KLOOGY's Avatar
L33t BMW Drivah
When I take the Navigation CD ROM out, and pop in an audio CD , it becomes a touch screen CD player, but it plays through an AUX source on the stock radio. I just wonder , if I upgrade to an aftermarket radio, if this function will still work. I dont want to buy a new radio, and pop in a CD into the Navigation, and not be able to hear it on the Max's sound system......got it ?....
Im not trying to add an extra screen.
Old Feb 14, 2004 | 04:14 PM
Cubanato's Avatar
talk to DON although u can come visit hime he will have the best advice and tips to offer
-J
Old Feb 14, 2004 | 04:24 PM
NT2SHBBY
Hey Kloogy- (aside from our differences)
looking at that pic (first time I've seen the navi up close) shows me that the HU is in fact separate from the screen-so I am assuming that the CD slot is behind the screen??
if thats the case than:
1) you'd have two CD slots (not a problem)
2) if you remove the HU by itself, do you see a connector attached to the screen???-this would assume to me that it is an aux port and should work with a new HU as long as it has one also
Old Feb 14, 2004 | 04:25 PM
Cubanato's Avatar
exactly jsut get a headunit with an aux imput
and wire the cd out into the aux in and u should be fine
-J
Old Feb 14, 2004 | 04:27 PM
KLOOGY's Avatar
L33t BMW Drivah
I have not pulled it out yet. I just looked on crutchfield and it says that NO aftermarket radios are compatible with this car....wtf ? I might have to yank it out, and take a closer look. The only reason I want to swap my radio, is to have XM or Sirius built in, and also send a clearer signal to my amps......Thx for the help so far, even you NT....
Old Feb 14, 2004 | 04:39 PM
NT2SHBBY
n/p bro--pull it out and find out-might be a special plug which means u SOL unfortunately......
oh and btw.....
SOHK 4 Life!
Old Feb 14, 2004 | 07:19 PM
Stardust's Avatar
F---ing Kangaroos
If it is in fact a touch screen CD player why is it that the NAV is not touch screen?
Old Feb 15, 2004 | 01:29 AM
KLOOGY's Avatar
L33t BMW Drivah
My Nav IS Touch screen.....Im not sure what you're reffering to....
Old Feb 15, 2004 | 03:10 AM
MyownNismo's Avatar
Future Camaro SS owner
Don't quote me but the way I see it is the CD player you have reads it as a dvd. So I think you best bet it to get this aftermarket headunit. From looking at your pics your headunit says AUX so you need a Aux output to hook the screen to.
ALpine DVA-7996 http://iweb.alpine-usa.com/pls/admn/...y=70&p_main=30
Old Feb 15, 2004 | 09:52 AM
Stardust's Avatar
F---ing Kangaroos
Nevermind, I had a brain fart. I was thinking of the new ones.
Old Feb 15, 2004 | 10:16 AM
NYC2SD's Avatar
I think there is more wiring logic built into the stock head unit than it appears. When the Nav voice comes on, it cuts out two channels so that you can hear directions.
Old Feb 15, 2004 | 02:01 PM
KLOOGY's Avatar
L33t BMW Drivah
Thats correct, BTW , you've got a PM..
Im just afraid of upgrading the headunit, and start finding out that little things in the Navigation software arent functioning the way they should. I was hoping someone had already been the guinea pig....
Old Feb 15, 2004 | 03:32 PM
MyownNismo's Avatar
You can always try and call some shops and ask if they have done a maxima with stock Navi. I can't tell unless it was right in front of me. but I think you would have to leave it. Cause the heater controls are built into the navi and cd player correct. But if you can fit the player I posted above in the place where the tape is you should be able to use the AUX the screen.
Old Feb 15, 2004 | 04:17 PM
subdocmax's Avatar
If you don't want the nav to work then you can do it, but you can make the unit work with amps and speakers if you want to know more about this you can give me a call at 480-510-3420 thanks David
Old Feb 15, 2004 | 05:01 PM
KLOOGY's Avatar
L33t BMW Drivah
You got PM ....
afshep
Oct 7, 2012 08:14 AM
