Is there a way to connect a laptop.......
Old Mar 10, 2001 | 09:31 AM
2001SE's Avatar
How can i connect my laptop to the Bose sound system.
Then i can use winamp and hear hundread of songs instead of burning CDs all the time.
Old Mar 10, 2001 | 09:53 AM
tomz17's Avatar
sure, get one of those portable CD player FM transmitters.... I've seen them in mail order, auto stores, internet, etc... Then you just plug that little doohicky into your laptop's audio out port, fiddle with the dial until you find a clean frequency, fire up winamp, and tune your FM car radio to the same frequency)
-Tom
PS.. super cool rainy day project...
goto a computer show, pick up a cheap used laptop w/ sound (make sure it has enough bhp to decode mp3's in realtime)
~$150-$300
Buy a power inverter (nothing big... ~$30)
Buy one of those FM transmitters ($~20)
and you got yourself a junior car computer... remove the battery, and you can have it start up/shut down with the car.... (or you can write a small program to have it shut down neatly when ac power is cut)
It would be useful if this laptop had a cd-rom (play burned mp3 discs), and useful if it had a big HD... (compgeeks.com was selling 20gb IBM hd's for ~$150 a few weeks ago)... that's enough to store WEEKS worth of music!!!!
Old Mar 10, 2001 | 10:22 AM
psing23's Avatar
what do u think is enough power to decode MP3's real time? cause i just got a little laptop that im using that has like i think a 125mhz processor... is it good enough? lemme know
Old Mar 10, 2001 | 10:33 AM
MaineI30's Avatar
Yup, burning CDs sucks. I have a mini-tower in the trunk. Someone else said you need an inverter -- you really shouldn't use one. You should power it directly from the 12v DC (a computer actually runs off 12v DC also)
Look around for ways to do this.. one good resource is:
http://www.mp3car.com
later,
/aac
Old Mar 10, 2001 | 11:58 AM
tomz17's Avatar
I'm sure that a really optimized mp3 player could play an mp3 off of a 486 DX processor.... Any pentium should do...
(ps... you don't have a 125 mhz processor, because they don't exist... maybe 120mhz ???, and that would with almost 99% certainty be a pentium class processor...)
As for the power inverter, it is the easiest way to accomplish your goal...(and for $30 will save you a lot of unecessary stress)
Powering a laptop via direct 12v current from your car could be DANGEROUS, if you do not know what you are doing!!! in a standard PC, you use 12V, 5V, and ~2-~3V !!!!, so plugging everything into 12v would be a bad idea... YOU HAVE TO KNOW EXACTLY what you are doing to make sure everything runs within spec !!!
-Tom
Old Mar 10, 2001 | 04:21 PM
MaineI30's Avatar
-Tom
[/I]
I agree with Tom here. Best way to be sure is to get a dc-to-dc power supply for your cpu.
best,
/aac
Old Mar 10, 2001 | 06:49 PM
max2kgle526's Avatar
http://bubblemax.homestead.com/files/maxp3.htm
CKNY's maxima.
Old Mar 10, 2001 | 08:04 PM
MaineI30's Avatar
CKNY's maxima.
I found inverters cause more problems than they're worth.
/aac
Old Mar 10, 2001 | 10:06 PM
2001SE's Avatar
thanks guys
this really helped
zmcneely13
Sep 26, 2015 02:26 PM
