passenger window not working
Old Feb 22, 2004 | 08:00 AM
SoonerFan's Avatar
Cletus
ok i did the blue LED bulb swap on my switches. i didnt read the warning about not trying to open up the passenger window switch. that switch is messed up and wont work. BUT now i cant even get the window to go down with the driver side switch!!! all the other windows work fine
i opened up the driver side switches again and everything looks fine.
so what is the problem?
could it be a fuse? or is there one for all the switches?
Old Feb 22, 2004 | 08:36 AM
SoonerFan's Avatar
Cletus
well it isnt the fuse.
i was right there is only one fuse marked "pwr wind"
Old Feb 22, 2004 | 08:51 AM
Ammi's Avatar
350 Detroit Muscle
were you able to lower the window from driver side before?
Old Feb 22, 2004 | 09:03 AM
SoonerFan's Avatar
Cletus
i did the passenger switches first. after i messed it up i could still lower it with driver switch.
then i did the driver switch and cant do it.
im afraid that the passanger switch shorted out and messed up the motor
Old Feb 22, 2004 | 09:19 AM
MaximaPolak's Avatar
i think you over heated the board.
I didn't do the front driver's nor passanger's side because they are a lower voltage than I expected. I need some smaller voltage LEDs if I want to change them. I did my rear switches though and they work fine.
Old Feb 22, 2004 | 09:22 AM
Ammi's Avatar
350 Detroit Muscle
if it's not the switch, it's definitely the motor. More $$$ out of your pocket now
Old Feb 22, 2004 | 09:23 AM
ZIPPIN's Avatar
Mauja He Mauja
the pass side window does not work in my car either. i can roll it up and down from the drivers switches...so i know it's not the motor...some prob with the switch...
Old Feb 22, 2004 | 09:43 AM
SoonerFan's Avatar
Cletus
the rear switches are the same as the front passenger. so i hooked one of those up to the passenger and it still wont work.
so im thinking its the motor...DAM IT
Old Feb 22, 2004 | 10:05 AM
Ammi's Avatar
350 Detroit Muscle
You probably just need a new switch
wojowojo16's Avatar
put in the old bulbs and take it to the dealer...do you have any warrenty left?
Old Feb 22, 2004 | 10:10 AM
SoonerFan's Avatar
Cletus
ok passenger window is working!!!!
i used a switch from the back door and after hooking it all up it works!!!!
so not the rear window wont go down even from the drivers door.
so basically if the switch is broken what ever window its on wont work even from drivers switch. i guess it has to work for the power to go through it even for the drivers switch. o well, front windows are the important ones
Old Mar 7, 2004 | 07:13 AM
custommaximaSE's Avatar
To buy new window switch from the dealer for the passenger side it only cost $27.30.
Old Mar 7, 2004 | 12:01 PM
thomasd cook's Avatar
I think you just need to check the ***** and springs on the switch itself. Make sure it is all seated properly when you put it back together. The window will not work if the switch is not put back together properly. I'm pretty sure it's in the switch. Try and put the switch back together properly. If you can't get it then buy another switch. But the problem does lie withing that switch. The motor isn't bad it's the ***** and springs are not set properly. Hit me back if it doesn't work.
Old Mar 7, 2004 | 12:05 PM
You don't need smaller LED's you need the proper resistor to wire in line in order to make the LED's work with a 12 volt source.
Old Mar 7, 2004 | 12:16 PM
PoLo's Avatar
2-Wheelin it...
watch out with the front drivers side....$115...i know from experience....
jerrod99_se-l
Aug 27, 2015 08:27 PM
george__
Aug 18, 2015 07:06 PM
KGMtech
Aug 18, 2015 09:21 AM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
