Those that have changed their fuel filters in 00-01 Maximas..
Old Feb 27, 2004 | 08:14 PM
00MaxSE's Avatar
Pointy Elbows
did you notice any difference in mpg? Does anyone have the write up and how much does the filter cost from DaveB? I plan to do this along with my brakes and spark plugs over spring break.
Old Feb 27, 2004 | 10:03 PM
FanaticMadMax's Avatar
Fuel Filter does not need to be replace according to the owner's manual due to the fact it's in the fuel tank. Nissan consider a maintanence free part. If you want, it's gonna be a quite a task to replace it. The part only cost 3 bucks for it. As far as getting to the tank, you have to remove the rear back seat. it's a very lenghty task. There was a write up somewhere on the post. It's not worth doing it if you don't want to get fuel smell and a mess. Yet, even break a connector on the fuel floater.
Old Feb 28, 2004 | 06:53 PM
00MaxSE's Avatar
Pointy Elbows
It's been discussed before and I still want to change my filter. Who's got the write up?
Old Feb 28, 2004 | 08:05 PM
spirilis's Avatar
I've done it. I even have a writeup with some pics from when I broke the fuel sender unit's supply line on the inside.
I didn't notice any difference in fuel economy, but did notice a DRAMATIC night-day difference in power. I guess mine was in horrible shape.
Check for any threads started by me... I started one which ended up in a writeup.
Old Mar 1, 2004 | 05:43 AM
00MaxSE's Avatar
Pointy Elbows
I would, but they won't let me search.
Old Mar 1, 2004 | 08:14 AM
thomasd cook's Avatar
This should be the link. I saved it because I've got a fuel filter and one day will try and swap it out. Hopefully right before I install NX.
Old Mar 1, 2004 | 08:21 AM
Y2KSESteve's Avatar
It isn't hard to do, just takes time. You should notice a different after doing it and nothing on a car is "maintenance free".
Old Mar 1, 2004 | 10:31 AM
panda_1's Avatar
when i went to change my fuel sender nissan told me that they did not sell the filter without the pump and it was 250 dollars. i also broke my sender which needs to get changed.
Old Mar 1, 2004 | 11:02 AM
BigDogJonx's Avatar
Thats what the dealer will tell you, but it can be bought from DaveB separately.
I changed mine last night, its not that hard of a task at all, just for me I got a small issue because I have the Walbro 255lph pump in there which is technically 1/8" longer than the stock pump. So its causing me some problems at the moment.
Dixit
Old Mar 1, 2004 | 11:14 AM
Cesar's Avatar
I do not thing a fuel filter would be $3. Eventough it is considered a maintenance free item it should be replaced when all other resources have been met ie: air filter, fuel injectors cleaned, etc. This should be left alone if possible (IMO)
Old Mar 1, 2004 | 11:20 AM
Colonel's Avatar
Old Fuddy Duddy
Why would all of a sudden you NOT want to change a FF? Every OTHER car in the world needs them changed...what monopoly does Nissan have JUST for the Maxima? A filter is a filter and filters have a life span. Because its in the fuel tank...nobody is sure what it is. I am confident Ill be replacing my every 30K.
I did it also, its not hard...do it when the gas light kicks on and dealing with fuel will be kept to the utmost mimimum.
From DaveB I believe the FF is like 12 bucks and the Gasket (PLEASE REPLACE IT) is like 9 bucks.
I was chasing a fuel mileage issue and my FF was NASTY. THe FF was the trick. Just because its in the fuel tank does not mean it does not need replacing. Nissan just has a bad design :gasp:
Old Mar 1, 2004 | 11:25 AM
panda_1's Avatar
what is dave b's number?
Old Mar 1, 2004 | 01:16 PM
Y2KSESteve's Avatar
888-254-6060 - Ask for Dave Burnette as there are two Dave B's at SouthPoint Nissan.
Old Mar 1, 2004 | 10:17 PM
panda_1's Avatar
The Fuel Filter Is The Filter At The End Of The Sender Reciever/fuel Pump Inside The Housing Right?
Old Mar 1, 2004 | 10:28 PM
BigDogJonx's Avatar
Yes its basically what the fuel pump goes into, that whole unit is the fuel filter.
Dixit
Y2KSESteve's Avatar
If it has a hole in it and is at the bottom, yes thats the filter.
Old Mar 1, 2004 | 10:41 PM
jimkim2004's Avatar
Am I missing something? Where is the link?
Old Mar 2, 2004 | 08:55 AM
Here it is. I thought I put it in. http://forums.maxima.org/showthread.php?t=276627
Old Mar 5, 2004 | 10:37 AM
Y2K1GLEMAX's Avatar
is teh fuel sensor in the same area? mine isnt workin so figured i can fix its in the same area. can anyone help?
Old Mar 5, 2004 | 10:39 AM
BigDogJonx's Avatar
Its all down there. When you pull the assembly out you will be putting out the entire unit.
Dixit
Old Mar 5, 2004 | 10:44 AM
Y2K1GLEMAX's Avatar
do u have a pic of the sensor?where can i get a new one and how much would it cost?
Old Mar 5, 2004 | 10:45 AM
Y2K1GLEMAX's Avatar
Old Mar 5, 2004 | 11:09 AM
spirilis's Avatar
Check the pics in my thread: http://forums.maxima.org/showthread.php?t=276627
The "sensor" is the whole top housing, which includes all the soldered wires/connectors/etc. It does not include the fuel return hose which snakes down to the bottom, nor the bottom chamber, nor the fuel pump.
I broke the fuel supply inlet on the inside of the "sensor" housing, that's why I posted that thread (the first pic in my first post is exactly that). I think it was $85 or so, can't quite remember
Old Mar 5, 2004 | 12:12 PM
Y2K1GLEMAX's Avatar
thanks. it shouldnt be that hard to change it right? can i find it at like a pep boys?
Old Mar 5, 2004 | 12:20 PM
spirilis's Avatar
No, you must buy it through a Nissan dealer.
You need the Fuel Filter ("fuel strainer assembly"), and replacement O-ring which goes around the lip of the fuel tank (to ensure proper sealing, since the O-ring gets crushed)
About $22 shipped from DAVEB (Dave Burnette) at South Point Nissan. You can find his contact info in other threads.
Old Mar 5, 2004 | 11:36 PM
wcasskicker's Avatar
Dam I need to replace it, does it worth to ship from Dave B's place to Vancouver Canada?
Old Mar 12, 2004 | 05:52 AM
00MaxSE's Avatar
Pointy Elbows
I just got mine from DaveB yesterday.
Old Mar 12, 2004 | 06:36 AM
HKMax's Avatar
Great write-up. This write up should be included in Installation/How-to's section. So that others with no search privilege can readily get an access to it.
Old Mar 12, 2004 | 08:55 AM
maseo77's Avatar
is there anyone in the md, va, d.c. area that i could pay to HELP me change my fuel filter
Old Mar 14, 2004 | 09:56 PM
Y2K1GLEMAX's Avatar
all of a sudden my fuel sensor started working again. anyone know what the problem couldve been
Old Mar 14, 2004 | 11:17 PM
aussie983's Avatar
this might be a stupid question, but how can you tell when your fuel sensor isnt working? does it throw a code?
Old Mar 15, 2004 | 03:47 AM
ZIPPIN's Avatar
Mauja He Mauja
i thought they lasted forever. but nothing lasts forever, when it comes to nissan
Old Mar 15, 2004 | 12:57 PM
Y2K1GLEMAX's Avatar
the gas would always look like its full
The Wizard
24
Oct 1, 2015 08:47 PM
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 20, 2015 08:22 AM
aminus21
Sep 12, 2015 04:53 PM
sdotcarter
Sep 2, 2015 09:53 PM
