How do you remove the brackets off the radio
Old Mar 6, 2004 | 12:41 PM
woosh's Avatar
I have a 2000 non-bose radio. How the hell do you guys remove those 6 black screws on each side that holds the entire radio/heat/AC controls to those rails?
The bottom 2 that goes into the black plastic is easy but I can't even budge tho others??? Need suggestions.
thanks
SHIFT_woosh
Old Mar 6, 2004 | 12:44 PM
Igor911's Avatar
use a drill with the phillips bit.
Some are harder to undo then others
Old Mar 6, 2004 | 01:37 PM
Bucket's Avatar
Put the radio on a countertop or bench. Use a phillips bit that is in good condition mounted in a drill. Line it up and press hard, then give the drill full power---making sure it's set to loosen. Those babies are really in there. All of mine made a CRACK sound as they broke loose.
Don't mess around with a regular screwdriver.
Someone posted this elsewhere, but I forget who it was. My thanks to them for saving me major grief.
Old Mar 6, 2004 | 02:02 PM
Ka$hThaRipper's Avatar
here's a follow up question
mine are like a biotch and a half to get out
i tried a few drills also, of various voltage, and none of them took it out
i have 4 scrwes left, i was told to use a drill bit to try to disintegrate them....but THAT didn't even work
now i got a few small screws that have a drill bit indentation in them going halfway thru.....i just guess to keep drilling? slightly bigger bit?
suggestions?
Old Mar 6, 2004 | 03:32 PM
BrandonSE's Avatar
LOL, funny because i did 2 radios in 97 maximas and one i got worked lik a charm the other was a pain. The easiest way is to actually turn it to tighten the screws, this in return will loosen it to take it off. Trust me it sounds retarded, but take a good phillips and tighten the screw just a little bit, once it cracks then loosen them badboys off
brandon
Old Mar 6, 2004 | 03:33 PM
slickrick's Avatar
keep drilling. it turned into a project to get my last 2 screws out. use a small fine bit to make a hole, then a bigger one to finish the job. ti takes a long *** time but it will work, trust me.
Old Mar 6, 2004 | 09:16 PM
2002 SE TX's Avatar
I had the same problem, and I used an impact driver. You get one for about $10 at an auto supply store. It's basically a spring-loaded screwdriver that you hit with a hammer. The spring forces all the energy from the hammer blow right into the screwdriver tip. The stuck screws popped right out and no, it didn't dmage the stock radio if you're wondering. I had to put the stock back in for a while when I was switching aftermarket units and it worked just fine.
Old Mar 6, 2004 | 09:29 PM
man you LOVE drilling dont u, even on the thread in audio/electronics, hahah...
i was just afraid of two things..
1. the metal shavings possibly damaging the h.u.
2. inadvertently going thru the entire screw and into the unit, b/c the screw is so small
Old Mar 6, 2004 | 09:59 PM
woosh's Avatar
Well, I damaged the head on 3 screws and gave up. I didn't get any of them out. I used good bits but it seems like the bits disintegrated the mating half of the philips screw. WTF was nissan thinking when they put those in?????
I'm so frustrated right now.
SHIFT_woosh
Old Mar 6, 2004 | 10:53 PM
slickrick's Avatar
yeah i lost a bit or 2 doing it. dont give up. its a pita for sure. and to kash.. i hate drilling but this damn maxima seems to force me to drill. i would have saved alot of time by just drilling in the 1st place. thats why i say drill, haha. when i tried to drill through i was also afraid of the shaving and damaging the h/u but i put the stock one back on after and it was just fine. if someone wanted to ever steal a stock h/u theyd have fun trying to get it out of the bracket.
Old Mar 6, 2004 | 11:19 PM
Mkang513's Avatar
You need a high power driver. I tried using the ones i had at home and actually broke two bits. I took it to my friends shop and used a stronger driver. Just press down HARD. We managed to get all of them out. The screws were useless afterwards though.
Old Mar 7, 2004 | 02:45 PM
SEDaveMax's Avatar
I just went through this a few weeks back. We ended up drilling them out. I think we lost 2 or 3 bits. I would imagine something with a lot of juice would help but if you don't get them early on it almost a lost cause because the screws are so soft and cheap. There's someone on here that is a senior installer at Best Buy who didn't have any problems.
Dave
02 Maxima SE
Apr 16, 2020 05:15 AM
Calabar
Oct 5, 2015 09:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
